Okay so we finally are getting nice weather and was able to work on the car. Firewall is completely out, drivers side floor pan is out, final measurements then trim for new pan, was able to expose the frame where I knew it was bad, torsion bar cross member is rusted where the front frame rail joins, front frame rail in this spot as well, what would be better to do, replace the torsion bar cross member and repair the front frame rail, replacing both, or repairing both, would have to weld braces in this area for support while this is going on, does anyone have pictures of this, so I can get an idea. What thickness of metal would I use for the frame repairs?
