Author Topic: U Joints  (Read 987 times)
Offline EMCD
U Joints
« on: November 10, 2016 - 11:17:28 AM »
I'd like to replace my u joint with more robust versions. What is a good recommendation?
Re: U Joints
« Reply #1 on: November 10, 2016 - 01:02:57 PM »
What do you have in there now?
Offline jhaag
Re: U Joints
« Reply #2 on: November 10, 2016 - 03:35:28 PM »
"Performance" u joints typically just eliminate the grease zerk which in turn eliminates the lubrication passages in the u joint. By doing that they should theoretically be stronger. But then you can no longer lube the joints. Not a good idea on a street car. Other choice would be a physically larger joint. That means different yokes and driveshaft. From my experience any quality aftermarket joint should serve you well in most street and mild race applications.
love 70 Challengers
Offline EMCD
Re: U Joints
« Reply #3 on: November 10, 2016 - 03:55:45 PM »
I'm guessing that I have the original factory joints from 1971. it's a standard 727 tranny with a 408 stroker with a bit of torque. I get a clunk at times shifting to reverse and don't want to jeopardize the car with a failed u joint at 80 mph on the highway. I like the pole-vault, but only in the Olympics.
Re: U Joints
« Reply #4 on: November 11, 2016 - 05:34:08 AM »
You can change from the Mopar joints to 1350's but as stated, to do that you need to buy a new drive shaft and yoke to do it.
Offline Aracer
Re: U Joints
« Reply #5 on: November 13, 2016 - 02:37:11 AM »
Spicer solid small joints only fit the axle end. They won't fit the small yoke on the tranny end so there I use the standard Dana/Spicer. Other brands are phony using a harder rubber on the cups to give the illusion of H.D.
     Driveline Service told me that the Brute Strength auto store ones I had brought it in with gave him problems on the spin up to speed. He wore them out, but that balancing is perfect for a 3" factory shaft. If it is balanced it can stand the end play and spin smooth. On the street, it would have probably made noise on deceleration like a worn out joint on a hilly freeway.
