Author Topic: 10 vs 29 Spline 8 3/4 Yoke, Is One Better/Stronger Than The Other?  (Read 4734 times)
Re: 10 vs 29 Spline 8 3/4 Yoke, Is One Better/Stronger Than The Other?
« Reply #15 on: November 23, 2016 - 04:23:52 PM »
I don't think the 8 3/4's are that easy to break.
Remember when going to the Dana you don't have the variety of gears to put in there that the 8 3/4 does.
 :iagree:  Dana's start at 3:54 then 3:73, 4:10 etc...  I sold mine (3:55 sure grip) before I installed my new motor/transmission. I didn't break it. If your planning on a street car with street radials like BFG T/A's you likely wouldn't get enough traction to break a 8 3/4 . I tend to overbuild stuff so I don't have to worry about doing it again if I upgrade in the future. I don't mind spending the money...ONCE!
Offline Aracer
« Reply #16 on: November 24, 2016 - 07:11:19 PM »
Before I bought the $100 spool from Dr.Diff,  I broke the steel set pin in pinion shaft of the 1972 cone sure grip. The pinion bearing was unaffected from the clunking.  I found a few tiny chips removed from the edge of the gears and reused them.           10 spline
