Author Topic: Alignment after new Leaf Springs?  (Read 968 times)
Offline EMCD
« on: November 10, 2016 - 04:13:07 PM »
got the stock ESPO leafs on order, do I need to get my car realigned? I just raised the front end up to stock height with new TBs.
Re: Alignment after new Leaf Springs?
« Reply #1 on: November 10, 2016 - 04:50:05 PM »
If the front end height was changed, you should have the alignment looked at.  If you didn't loosen the LCA nut before you raised the front end, the bushing could be preloaded at ride height.  Loosen the nut so the bushing centers itself, then retighten the nut.
Offline EMCD
« Reply #2 on: November 10, 2016 - 05:53:23 PM »
I had it aligned after installing the TBs. any reason to do it again for the rear springs?
Offline rUNCHARGER
« Reply #3 on: November 10, 2016 - 06:07:23 PM »
I wouldn't bother.
Sheldon
Offline EMCD
« Reply #4 on: November 10, 2016 - 06:59:27 PM »
i couldn't think of a reason why I'd need to, but I figured I should ask the experts.
Offline GoodysGotaCuda
« Reply #5 on: November 10, 2016 - 09:57:11 PM »
Technically it should be checked with the adjustment of ride height. It'd also be nice to know if the rear axle is centered and perpendicular to the centerline of the car (thrust angle).
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline 72bluNblu
« Reply #6 on: November 10, 2016 - 11:06:09 PM »
Well, if the ride height in the back changes it does change the caster reading up front (even if nothing in the front changes). But if the rear height doesn't change too much it probably doesn't matter. Won't change the camber or toe, and unless you add or subtract a lot of rake the caster won't change dramatically.
