Author Topic: Keisler TREMEC TKO 600 Question / Dilemma  (Read 1142 times)
Offline daveh
« on: November 12, 2016 - 12:36:15 PM »
Hey guys,
As many of you know I'm putting back together my 71 Challenger Convertible after just getting it back from being painted.  I welded up a jig for the K-member, rebuilt the 340 and suspention.  Up to this point I have the suspension, K-member and 340 assembled on the jig.
Before Keisler went out of business I bought a complete kit TREMEC TKO 600 from soup to nuts from them. Everything I needed to make the conversion to the 5 speed.
I installed the Flywheel last night with ARP fasteners and then went to install the clutch and pressure plate and none of the holes lined up with the Flywheel.
Well come to find out (no big surprise from Keisler) I was sent a 10.5" Flywheel and an 11" clutch and pressure plate.  I caller American Powertrain to talk to them but its a weekend and they are closed.  I just can't pick a new clutch and pressure plate I need one specific for the TKO 600 with the correct splines.
Below is what I was sent what do you guys suggest? I like the Billet flywheel over the Sachs clutch just not sure which clutch and pressure plate to get.  Any and all suggestions are appreciated. Its a street car only so I don't thik a 10.5" set up will make a huge difference over an 11" set up.
Flywheel:
Ram 1503 Billet Steel Flywheel. 10.5"(10.95") B&B Diaphragm, 130 Tooth.
Clutch and Pressure Plate:
Sachs PC1877-KE, Item CLA-PK1877KW, 11"
Thanks
« Last Edit: November 12, 2016 - 01:03:16 PM by daveh »
Offline GoodysGotaCuda
Re: Keisler TREMEC TKO 600 Question / Dilemma
« Reply #1 on: November 12, 2016 - 06:55:10 PM »
You may try SST, Keisler is now Silver Sport Transmissions
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline daveh
« Reply #2 on: November 12, 2016 - 09:10:10 PM »
Yep they are on the list for Monday as well.  Thanks
Offline daveh
« Reply #3 on: November 14, 2016 - 03:26:23 PM »
Update:
I got ahold of Ben at Silver Sport Transmissions.  They bought all of Keislers inventory and he couldn't have been nicer.  He knew exactly what I was talking about and hooked me up with the correct 10.5" clutch and pressure plate at a reasonable price.  So I'm back on track again.  Thanks
Anyone in need of a new 11" clutch and pressure plate let me know and I will make you a great deal.
« Reply #4 on: November 14, 2016 - 04:37:09 PM »
Excellent! I have nothing but good things to say about SST. I bought my T56 Magnum conversion from them.
1976 Dodge Warlock
