OK, so I finally got around to setting up the oil pan. First why 2 bolts for each? I used one for the main cap (stud with cap nut). Also, my pan bolts are long, but not too long, so they worked well. After drilling the two holes in the rear, I will need to go buy two more pan bolts. And the 'juant near the timing cover,' well its going to leak cause I don't see it.
And the next trick is the dip stick - um, where in the heck does this go? (please keep it G rated).
Thanks in advance
