Author Topic: fixed quarter glass help  (Read 898 times)
Offline vilzrod
« on: November 13, 2016 - 10:01:43 AM »
Guys.... I want  to have my quarter windows fixed  solid....... but need the oem mounts/ brackets anyone know where and what exactly I need ?..
 car is  1970 Cuda    email   vilzrod@hotmail.com  THANKS!
« Last Edit: November 13, 2016 - 05:41:04 PM by vilzrod »
Offline anlauto
Re: fixed quarter glass help
« Reply #1 on: November 13, 2016 - 10:10:46 AM »
It's my understanding that everything is the same except the glass is just bolted solid to the track. :2cents:
Offline vilzrod
« Reply #2 on: November 13, 2016 - 05:42:22 PM »
there must be different mount as the reg holds the glass... anyone with fixed windows help?
Offline anlauto
« Reply #3 on: November 13, 2016 - 05:52:27 PM »
The regulator DOES NOT hold the glass. The bottom bolt on the window secures the glass to the track You do not use the white slider block.. The other bolt uses the black bushing to secure the window to the track also. It's very simple.
« Last Edit: November 13, 2016 - 05:55:01 PM by anlauto »
Offline vilzrod
« Reply #4 on: November 13, 2016 - 08:50:47 PM »
I see ... so put it back together less the regulator and use a bolt ther ... and the window will stay tight up against the weatherstrip ?....thx for the reply
Offline EB3-GranCoupe
  • BP23 U0B
« Reply #5 on: November 14, 2016 - 05:58:25 PM »
 :popcorn:
