Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
The Body Shop
(Moderator:
Chryco Psycho
Door window adjustment
« previous
next »
Print
Pages: [
1
Author
Topic: Door window adjustment (Read 1091 times)
money pit
Jr. Member
on:
November 13, 2016 - 06:18:27 PM »
On my 73 challenger I notice there is a gap between the window glass on the door and the rubber seal on the rear glass. The top and front of the glass seem to fit tight against the rubber seal on the body. Also the door is difficult to close. I noticed that the door gap isn't aligned. The edge of the door is not flush with the body. It sticks out about a quarter of an inch. Is this a door alignment problem or do I need to adjust the glass. I had the glass out to repair the rollers on the window regulator. I wasn't sure if the glass could be adjusted. Thanks
Logged
anlauto
Permanent Resident
I'm Alan G...I'm a Mopar Addict
Re: Door window adjustment
Reply #1 on:
November 13, 2016 - 06:32:15 PM »
Is the door gap correct when the door is closed with the window rolled down ?
Logged
money pit
Jr. Member
Reply #2 on:
November 14, 2016 - 07:08:53 AM »
Let me check. If it is, where do I go from there?
Logged
gyman98
Jr. Member
Reply #3 on:
November 14, 2016 - 09:04:39 AM »
Last Edit: November 14, 2016 - 09:08:26 AM by gyman98
Logged
1970 hemicuda convertible clone 426/727 3.23 8 3/4 suregrip
money pit
Jr. Member
Reply #4 on:
November 15, 2016 - 12:44:30 AM »
Thanks I appreciate your info.
Logged
Racer57
Sr. Member
Reply #5 on:
November 16, 2016 - 09:48:06 PM »
While re-aligning mine, I found that I needed to loosen EVERYTHING and slowly tighten everything back up. If you only move what you think is needed, it will never work.
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
The Body Shop
(Moderator:
Chryco Psycho
