Author Topic: Seat track disassembly?  (Read 826 times)
Offline cuda2420
« on: November 15, 2016 - 07:03:25 AM »
I'm in the process of restoring the seats in my 1970 Cuda and I want to disassemble and clean and the seat tracks.
How do I disassemble the seat tracks?
Re: Seat track disassembly?
« Reply #1 on: November 15, 2016 - 09:26:49 AM »
If you don't have any broken parts, you don't really need to take them apart.  I didn't take my Challenger tracks apart.  I just cleaned the old grease out of them, repainted and re-lubed them.  On my Dart, I was missing one of the rollers and cages.  They were also really rusty and nasty.  In order to get the two sections apart, you need to drill out and remove one of the rivets.  With that rivet removed, the two sections will come apart.  You can replace the rivet with an allen head bolt.
When this question came up the last time, someone posted a link to a good write up on how to do it.  Do a search for it.  That will help you more then the few pictures that I have.
Offline dakota
« Reply #2 on: November 15, 2016 - 03:18:00 PM »
There's a small tab on the end of each outer channel that has to be bent back to get at the bearings.  I think I have some pictures - will post them tonight if I can find them.
Offline dakota
« Reply #3 on: November 15, 2016 - 03:33:43 PM »
Some pics can be found with this link which also has a link to the write up that I believe Burdar is referring to:
http://www.cuda-challenger.com/cc/index.php?topic=97139.msg1032719#msg1032719
Offline cuda2420
« Reply #4 on: November 16, 2016 - 05:08:39 AM »
Thanks a lot for good Info!
