Author Topic: 1970 Challenger door panel inserts  (Read 1428 times)
Offline brotow
  • There really is a Challenger in the backround
« on: November 16, 2016 - 04:58:45 PM »
Whats the best way of attaching the metal tri star emblem back on the door panel inserts after I replace the vinyl.  I was thinking of using 5 minute epoxy on the back.
70 Chall. vert.(in process) - 73 Amx -74 Javelin- 87 Wrangler-02 Sebring conv. 2005 Crossfire srt roadster
Re: 1970 Challenger door panel inserts
« Reply #1 on: November 16, 2016 - 05:11:28 PM »
I just took some clear silicone and applied a very small amount to each pin with a toothpick.  I only had one small area where some squeezed out.  You wouldn't have seen it if you weren't looking for it.  Once it was completely dry, I removed that little piece of silicone with a new razor blade.
Offline Katfish
  • 70 Challenger
« Reply #2 on: November 16, 2016 - 05:46:42 PM »
I used epoxy on mine after recovering it with a carbon fiber decal.
Offline EV2RTSE
« Reply #3 on: November 17, 2016 - 01:25:35 PM »
I used some JB Weld when I redid mine.
Offline brotow
« Reply #4 on: November 17, 2016 - 06:45:39 PM »
Thanks everyone,I'll probably use both epoxy  on the rear and silicon on the front.
« Reply #5 on: November 17, 2016 - 09:59:04 PM »
Wouldn't use anything on the front.  :2cents:
Offline Katfish
  • 70 Challenger
« Reply #6 on: November 18, 2016 - 12:35:51 AM »
Agreed, no need
Offline brotow
« Reply #7 on: November 18, 2016 - 09:31:44 AM »
Ok nothing in the front
« Reply #8 on: November 18, 2016 - 12:01:10 PM »
I put the silicone on the pins before pushing them through the holes.
« Reply #9 on: November 21, 2016 - 06:55:07 AM »
I used a drop of crazy glue on the back of each pin. Just about any adhesive will work.
