Author Topic: Anyone familiar with Vintage Air Kits  (Read 782 times)
Offline GoodysGotaCuda
« on: November 17, 2016 - 07:58:20 PM »
Their sales guy is one of the least enthusiastic I have tried to work with through this car build and has resorted to just sending me hot-links to installation instructions to field my questions.
My install is a hodge-podge configuration. I have a non-A/C Barracuda that I am buying a factory A/C dash for [standard gauges], therefore my firewall does not have any A/C holes in it. I am trying to determine what Evaporator kit I need and what control panel kit I need. [they have different install instructions]
Does anyone know what the differences are in their w/Factory Air and w/o Factory Air evaporator kits? Same for the control panel kits.
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline anlauto
Re: Anyone familiar with Vintage Air Kits
« Reply #1 on: November 17, 2016 - 08:17:58 PM »
I bought the kit for a non AC car.....I would assume the only difference as far as the evaporator is concerned would be the firewall plate that the hoses exit through :2cents: I tossed all that stuff and ran the hoses in the wheel well any how. The control panel is more based on rally dash or non rally dash
Offline Mickm
« Reply #2 on: November 26, 2016 - 08:26:53 PM »
GoogysGotaCuda, my 'Cuda was not an original air car so I purchased the "non-air" kit. When I sent my dash pad to Just Dashes, I had them put the cut-outs for the a/c vents.
The difference between the two is the  vents (obviously) as the non air set up has a small rectangular panel that bolts to the bottom of the dash that houses three vents. As for the control panel, they should be the same.
When I changed to the air dash, I had to find a set of original  vents (which are not reproduced) then order a set of adapters from Vintage Air that fits their hoses to the OEM vents.
Hope this helps,
Cheers!
Mickm
MickM
