Author Topic: Positive battery cable  (Read 1934 times)
Offline bc3j
« on: November 18, 2016 - 07:38:49 PM »
Looking for some clarification on a positive battery cable for 70 Challenger RT big block (non hemi). The pictures of the cables have an extra connector not found in my FSM electrical diagram. As I look at the cable, I see the connection to the battery relay post and the battery post on the starter.  There is another connector on the positive cable near the starter connector that I can not figure out where it goes. The FSM shows S5-12BR coming from the starter solenoid to the starter relay that appears independent of the positive cable.
Here is what I'm looking at. http://www.megapartsusa.com/proddetail.asp?prod=102%2DBC002P%2DE&cat=404
Need some guidance. It's the black forked connector that has me puzzled. Thanks.
« Last Edit: November 18, 2016 - 07:43:35 PM by bc3j »
Re: Positive battery cable
« Reply #1 on: November 18, 2016 - 09:57:23 PM »
The third wire goes to the starter relay. From the relay, it goes to the molded connector at the starter.
That's an expensive cable. Check a Chrysler dealer for a cable. My small block Challenger cable was around $30 from Chrysler. It wasn't a generic cable from a parts store.
« Last Edit: November 18, 2016 - 10:02:17 PM by burdar »
Offline bc3j
« Reply #2 on: November 18, 2016 - 10:25:51 PM »
I try the dealer thanks. So the forked shaped one also goes to the starter relay?  I know one goes to the battery post on the relay. My current cable is generic and does not have that third wire. The goal is to get an oem cable.
« Last Edit: November 18, 2016 - 10:28:45 PM by bc3j »
Offline 73440
« Reply #3 on: November 19, 2016 - 12:23:52 AM »
I think that is a fit all year and car cable, your number you mentioned matches the FSM only showing two wires, starter and relay.
OK to have an extra wire to tie into for power , I would think.
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
« Reply #4 on: November 19, 2016 - 06:53:24 AM »
Offline bc3j
« Reply #5 on: November 19, 2016 - 08:56:44 AM »
Thanks guys for the input. For sure Vans is cheaper. Must have missed them cause they never came up for me on Internet searches.
« Last Edit: November 19, 2016 - 08:58:50 AM by bc3j »
Offline anlauto
« Reply #6 on: November 19, 2016 - 09:06:47 AM »
The price difference is because the one you found at MEGA Parts is concourse correct, where as the one at VANS is a generic one. Big difference in the details equates to a big difference in price. Both have their place in the market. :2cents:
