Author Topic: Window trim studs  (Read 1139 times)
Window trim studs
« on: November 20, 2016 - 10:46:56 AM »
Got  the backlight out to examine the condition of the channel and prepare it  for  a reseal. I've noticed several of the trim mounting clips studs are missing. Is there a company out there that makes replacement studs or should I not worry about that and use the screw in style?  Its a '74 base model so no need for absolutely accurate methods here.
Offline anlauto
Re: Window trim studs
« Reply #1 on: November 20, 2016 - 11:53:17 AM »
Offline rhamson
« Reply #2 on: November 22, 2016 - 09:43:56 AM »
There are blind rivet studs available. The screw on type have a tendency to strip over time.
http://www.car-pak.com/Fasteners/c22/p8991/99-8549/product_info.html
« Last Edit: November 23, 2016 - 01:19:31 PM by rhamson »
