If your gonna do a stroker get the best heads you can buy to feed it or you'll have 360 power with worse gas mileage for your efforts... they do have RHS indy head with the regular shaft mount rockers and you can reuse the factory rockers. With a 2.02 1.60 setup and a bowl blend your looking at 1500 ready to roll, a good stroker kit is around 2k, and that gets you mostly there depending on intake/carb/headers that you have available now?? Machine work prices vary to much to quote, but if the block is solid than it shouldn't need more than deck, bore, and hone.
