Author Topic: Sealing the cabin from the firewall  (Read 1072 times)
Offline wantone
  • (O O {]{]{]||[}[}[} O O)
« on: November 25, 2016 - 03:00:13 AM »
I have all sorts of areas - like the coolant hoses - that don't seal from the cabin and i'm sucking fumes and heat... makes the ride LOUD and sucky.
How do I go about sealing these areas w/o making a mess or an ugly situation?
Want one?  Got one! ... finally
Re: Sealing the cabin from the firewall
« Reply #1 on: November 25, 2016 - 10:10:03 AM »
Offline wantone
« Reply #2 on: November 25, 2016 - 05:49:06 PM »
HOLY CRAP... My car didn't have any of these installed when I got it...  &$%^#%^$^%()   I never knew these were... Ayyye
Offline jimynick
« Reply #3 on: November 25, 2016 - 09:46:18 PM »
Detroit make a good kit and I used them on my car as well. There is a seal for everything that bolts through the firewall, right down to the mounting bolts for the emergency brake bracket. There is also a rubber boot for the clutch rod should you have one. If the PO didn't put the new seals on the heater core in/outlets, you've got some fun on your hands. Good luck  :cheers:
« Reply #4 on: November 26, 2016 - 12:12:51 AM »
If the previous person didn't put those in, what else did he not do?
You need a full check up.   :2cents:
