Author Topic: 1970 challenger convertible rear seat upholstery directions  (Read 1759 times)
Offline brotow
  • There really is a Challenger in the backround
« on: November 25, 2016 - 07:48:38 PM »
Does any one have a picture of a convertible upper rear seat(back) where the seat cover is hog ringed to the lower part of the frame. I think it goes on the wide horizontal part of the frame but it would have to really stretch the vinyle to reach that far.
70 Chall. vert.(in process) - 73 Amx -74 Javelin- 87 Wrangler-02 Sebring conv. 2005 Crossfire srt roadster
Offline 1 Wild R/T
Re: 1970 challenger convertible rear seat upholstery directions
« Reply #1 on: November 25, 2016 - 10:44:41 PM »
No picture but yeah, about 1/3-1/2 way down....
Offline brotow
« Reply #2 on: November 26, 2016 - 12:57:29 PM »
I think I fiquired it out, it could only be attached to the lower of the spring frame where the springs are asttached(indicated by the arrows). To mount it to the wide frame part there would be too much tension on the  vinyl.
« Last Edit: November 26, 2016 - 01:01:32 PM by brotow »
Offline Nel
« Reply #3 on: November 26, 2016 - 09:33:11 PM »
Been  a long time since I did mine, but I'm sure your are right
Offline CudamanTom
« Reply #4 on: November 27, 2016 - 10:47:47 AM »
Not sure where you got your seat covers but here is how mine turned out when I reupholstered my cuda convertible seats. I got my seat covers from Legendary.
1971 Cuda 440-727 - (clone)
Because I like it fast!!!
Offline 1 Wild R/T
« Reply #5 on: November 27, 2016 - 11:24:17 AM »
Thats how mine are as well...
Offline CudamanTom
« Reply #6 on: November 27, 2016 - 12:05:35 PM »
You need to start at the top back bar, attach the hog rings.
Then rub down the material in the front.
I will add, it's a VERY tight fit.
If you have too much foam/padding up top, that will cause problems as well.
Offline brotow
« Reply #7 on: November 27, 2016 - 12:24:15 PM »
Also have legendary covers, I originally had PG Classic Restoration Parts pui? (garbage),less padding, shorter over hang material behind rear upper seat, sides of the rear upper seat too short.  I will try to stretch and attach properly.  Thank you for the pictures
« Last Edit: November 27, 2016 - 05:49:42 PM by brotow »
