Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
The Rest of the Tech
(Moderator:
Chryco Psycho
Windsheild and back Glass
« previous
next »
Print
Pages: [
1
Author
Topic: Windsheild and back Glass (Read 1154 times)
DirksCuda
Jr. Member
on:
November 26, 2016 - 01:58:50 PM »
I'm getting ready to install the front and back glass in my 1970 Cuda. what I need to know is do they take a rubber seal or can u use the silicone like the new ones Thanks Dirk
Logged
70chall440
Sr. Resident
Re: Windsheild and back Glass
Reply #1 on:
November 26, 2016 - 02:15:55 PM »
Originally they were installed with Bhytle tape I believe, however you can/should install them using modern methods (primer, then window adhesive).
Logged
Current Mopar
Past Mopars
anlauto
Permanent Resident
I'm Alan G...I'm a Mopar Addict
Reply #2 on:
November 26, 2016 - 02:26:54 PM »
You don't want to use silicone, you would need the proper urethane
Logged
jimynick
Resident
Reply #3 on:
November 26, 2016 - 04:15:40 PM »
There's more to it than meets the eye. As mentioned, you should use either butyl tape or a high modulus urethane. Then there's making sure the clips are all on and the right height and matching the adhesive accordingly so that you can get said mldgs on once the glass is in place. There were also rubber support blocks that went in the bottom channel to support the glass and prevent it's sliding down. Make sure you clean the glass properly and use a primer that must be carefully applied so as to not show up once the glass is installed- and so on. The going rate for a w/s installation around here is around $100; is it worth it? Especially if you happen to clip an edge and crack it? Your call. Good luck.
Logged
dougs bs23
Sr. Member
Reply #4 on:
December 02, 2016 - 11:02:14 PM »
3M makes both the ribbon sealer and windo-weld urethane. Both should be available at your local auto parts stores
Logged
see Bill run go Navy football///fly navy
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
