Can Anyone Help Me With This?
Author Topic: Can Anyone Help Me With This?  (Read 2821 times)
Offline 04lbram
« on: June 26, 2005 - 08:34:59 AM »
Hello and good day to all. I'm just wondering how do you take off the part I circled in red. Would anyone know what type of tool(s) I would need? Just let me know and I posted it here because I would be more likely to get an answer and get it quick as I'm new to this and what not. Thank you.
04lbram
71 Dodge Challenger R/T Clone; 383 Big Block with a few goodies and good ole 14" Slot Rims
Offline torredcuda
  • Epping NH joined 11/23/03
Re: Can Anyone Help Me With This?
« Reply #1 on: June 26, 2005 - 09:56:13 AM »
You need a steering wheel puller.You can buy it as a set from most auto parts stores or tool dealers.
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
Offline 04lbram
« Reply #2 on: June 26, 2005 - 09:58:17 AM »
Thank you and sorry for the ignorance. This is the first classic car I have owned so the rest of the board please bare with the newbie here.
Offline 4Cruizn
  • HEMI FISH
« Reply #3 on: June 26, 2005 - 10:01:49 AM »
Don't sweat it . . . everyone in new at one point or another!   :thumbs:  I would put the nut on the end to protect those threads when using the puller.   :madvibe:
Offline 04lbram
« Reply #4 on: June 26, 2005 - 10:28:03 AM »
Thank you for the advice. I still have some work on the car to do such as seat belts. But, for now I need to get my hazards and my turn signal working.
« Reply #5 on: June 26, 2005 - 11:09:27 AM »
Those steering wheels don't give it up easy.  :banghead: :banghead: :banghead: They must use lock-tite or something at the factory, because once you have them off once, you can just use your hands after that. The steering wheel puller kits run about 20 some dollars, I believe. That's your only way out. Sitting there and pulling won't cut it. Don't ask me how I know.  :stomp: :stomp: :stomp:
Offline GoodysGotaCuda
« Reply #6 on: June 26, 2005 - 11:57:38 AM »
I have a puller that wouldnt work on my cuda. the supplied bolts werent long enough to reach all the way in there....keep that in mind...
Not sure what kinda wheel i wanna go with if/when i change it  :beer:
-Goody
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline 04lbram
« Reply #7 on: June 26, 2005 - 12:20:10 PM »
Thanks guys. Goody what type of puller did you use where did you get it from so I know what to avoid?
Offline 1973challenger360
« Reply #8 on: June 26, 2005 - 12:23:32 PM »
schucks cheaker kragen   will let you use them if you buy it in full and then they return money when you bring it back.
Offline 70RT440SHAKER
    • Challenger R/T
« Reply #9 on: June 26, 2005 - 01:53:15 PM »
I just build my own from a flat steel 3/8 thick bar, drilled 3 holes, threaded rod steel, 1 nut welded on center hole, the other on the end of the rod, and two long bolts to mount in the steering tube can bottom.
Takes 10 minutes
« Reply #10 on: June 26, 2005 - 02:56:53 PM »
I had to get 6" long bolts & make a new center bolt for the puller to get them off properly
Offline 04lbram
« Reply #11 on: July 06, 2005 - 11:33:16 PM »
Well, just ordered one from Year one and bolts not long enough so looks like 6 inch bolts for me as well.
Offline matt63
« Reply #12 on: July 14, 2005 - 09:16:06 PM »
I used redi-rod (threaded rod) and cut it to length.  This might be easier to find than 6 inch bolts.
Matt in Edmonton
'68 Valiant
Offline AprilsPink72Cuda
  • Global Moderator
  • 1972 'Cuda 340/Wappingers Falls, NY
    • Klondike's Website (Check it out!)
« Reply #13 on: July 18, 2005 - 08:39:03 PM »
We did the same thing.
