Author Topic: Ground straps  (Read 1161 times)
Offline bc3j
Ground straps
« on: November 30, 2016 - 04:08:24 PM »
A question for you restoration guys...I have a '70 Challenger RT N code motor with air. Did Mopar ever attach ground straps to the exhaust manifolds? The passenger side goes from the exhaust to the fender. The driver's side goes from the exhaust to the frame. Don't know if that is a previous owner attachment or did that actually come that way from the factory. Thanks.
Offline anlauto
Re: Ground straps
« Reply #1 on: November 30, 2016 - 04:13:06 PM »
The only ground strap on a 1970 383 would be with the negative battery cable. The large cable bolts to the engine, a small cable bolts to the rad support and of course they both connect to the battery as one.
No other ground cables :2cents:
Re: Ground straps
« Reply #2 on: November 30, 2016 - 04:55:53 PM »
Sometime in 73, they added another ground cable from the back of the cylinder head to the firewall.  They must have seen a need for it or they wouldn't have gone to the expense.  It wouldn't hurt to add one.  I'm sure you could find a way to hide it if you want it to look stock.
Offline bc3j
Re: Ground straps
« Reply #3 on: November 30, 2016 - 05:50:38 PM »
Thanks guys. It just didn't look right to me. The wires have been there for awhile. One wire is missing about 1/3 of the insulation. If anything, I'll look into replacing them with better wiring and try to hide them. The goal is to be stock appearing. Thanks again.
Offline Cudaragtop
  • Woulda Shoulda Cuda! Randy
Re: Ground straps
« Reply #4 on: November 30, 2016 - 09:17:47 PM »
When it comes to electrical, you can never have too many grounds. Unless looking correct is more important...   :bricks1:
- Randy D.
1 of 88 1970 340 4-Speed 'Cuda Convertibles
69 Barracuda Fastback Project Album https://goo.gl/photos/XjsAsx4LDo7psimU8
----o00o--'(_)'--o00o----
Re: Ground straps
« Reply #5 on: December 01, 2016 - 09:36:49 AM »
The factory ground strap mention above was a flat braided wire mesh with no insulation running from the head to the firewall. It was not a typical 12ga insulated copper wire. They are pretty unobtrusive looking if you wanted to add one.
