Author Topic: Looking for these 2 parts  (Read 2525 times)
Offline KZ
« on: December 01, 2016 - 10:46:40 AM »
1. I am looking for a right side (passenger side) Kelsey-Hayes
front caliper for my 1970 Dodge Challenger, I attach a picture of the
backside of the left caliper, I am looking for a similar piece for the
right side.
2. Also, looking for the front bushings for the leaf springs
Re: Looking for these 2 parts
« Reply #1 on: December 01, 2016 - 10:54:37 AM »
Is there a reason why you can't buy a reman from a parts store?
Offline KZ
« Reply #2 on: December 01, 2016 - 10:56:26 AM »
I am doing an OEM restoration.
« Reply #3 on: December 01, 2016 - 11:18:55 AM »
So you're looking for a caliper with those exact numbers on it?
Is the "211" number a casting date?  If so, would that mean the 21st week of 71?
« Last Edit: December 01, 2016 - 11:22:18 AM by burdar »
Offline KZ
« Reply #4 on: December 01, 2016 - 11:20:53 AM »
In perfect world yes, but not sure if that is possible, but wanted to at least put it out there for anyone who could help
« Reply #5 on: December 01, 2016 - 11:25:49 AM »
A parts store should have original calipers that have been rebuilt.  They may or may not have numbers you want.  Unless you are building a car to be judged in OE judging, those should work for you.
That one you pictured looks like it's been blasted which would not be the correct finish for an OE judged car.  I also edited my above response and questioned the "211" number on the one you pictured.  If that's a casting date, it wouldn't be correct for a 70 model year Challenger.  It all depends on what kind of car your building.
Offline KZ
« Reply #6 on: December 01, 2016 - 11:29:54 AM »
I am not sure about casting numbers, I think there are several different numbers out there, the car's build date was Dec. 1, 1969, the engine build date was 11-11-69, the left caliper is original, and yes, has been blasted, I asked RAMMAN about the numbers on those calipers and I cannot remember what he told me but pretty sure there are no date codes on the calipers but I am by no means an expert on the subject
« Reply #7 on: December 01, 2016 - 11:34:41 AM »
Personally, I'd order in a rebuilt caliper from your local parts store and see what comes in.  If you don't like it, you don't have to buy it.  I bought replacement calipers for my Challenger from Car Quest many years ago.  They looked exactly like my originals except for some numbering.  I kept my originals and didn't turn them back in as cores.
It's possible that original cores have dried up and parts stores are using "new" castings.  You'd have to order one and find out.  Good luck with the build.
Offline KZ
« Reply #8 on: December 01, 2016 - 11:37:00 AM »
Thanks, that is pretty much what the guy said who is doing gym restoration, but I thought I wold send a feeler out to see if I was lucky enough to get any hits
thanks
Offline timbbuc2
« Reply #9 on: December 01, 2016 - 11:47:17 AM »
Front spring bushings I bought at OReilys
Offline Moparparts
« Reply #10 on: December 04, 2016 - 09:05:02 PM »
I have a right side KH disc brake caliper like that available. PM or e-mail me for details
Offline 68bee
« Reply #11 on: December 08, 2016 - 09:37:11 PM »
That is a 1971 caliper. The casting number on a 1970 is KH80012   Date code is upper left.
« Last Edit: December 08, 2016 - 10:13:05 PM by 68bee »
Offline anlauto
« Reply #12 on: December 08, 2016 - 10:29:16 PM »
I usually tell quick by looking at the hole on the top. 70's had a much larger hole. :2cents:
« Last Edit: December 09, 2016 - 06:32:16 AM by anlauto »
Offline brotow
  • There really is a Challenger in the backround
« Reply #13 on: December 08, 2016 - 11:28:32 PM »
« Last Edit: December 09, 2016 - 08:41:38 PM by brotow »
70 Chall. vert.(in process) - 73 Amx -74 Javelin- 87 Wrangler-02 Sebring conv. 2005 Crossfire srt roadster
Offline JH27N0B
« Reply #14 on: December 08, 2016 - 11:39:34 PM »
Seems like the rebuilt calipers from the parts stores all end up being later style.
I needed a pair for my T/A restoration, and put a wanted ad on Moparts last spring, and had a number of people contact me with correct cores.  I bought a properly date coded set off one member, and sent them to Brake and Equipment warehouse to be rebuilt.  All in all, when all is said and done, it wasn't cheap, I have over $250 in my calipers and another $175 in the new restoration hardware kit that's on the market with correct slider pins and spacers etc, but the end results look nice!
The cores are not too rare but you have to search around for people with big hoards of parts to find them.
