Author Topic: Heater blower motor wheel  (Read 760 times)
Offline 4 speed fish
« on: December 04, 2016 - 09:00:44 PM »
Is there a trick to getting the blower fan wheel off?Thanks
Offline jimynick
Re: Heater blower motor wheel
« Reply #1 on: December 04, 2016 - 09:07:42 PM »
They're a close fit and get rusted on pretty good. I'd try soaking the fan's collar where it goes over the shaft with a good penetrant for a few (2-3) days and see if you can get a pair of screwdrivers under the collar and get it to move a wee bit with an eye to working it loose. Having said that, my own experience required taking a scrap piece of sheet metal and cutting a groove in it for a heat shield and quickly/accurately heating that swine collar with an oxy/ac torch and a #4 tip. It came right off and you'd want to have a spritz gun with water to cool things off asap. There's a seal and bushing in that end of the fan assembly so don't go nuts with the heat and you should be good. Took me 2 minutes, literally. Remember, when dealing with old cars, carefully applied heat is your friend.  :cheers:
« Last Edit: December 04, 2016 - 09:09:40 PM by jimynick »
« Reply #2 on: December 05, 2016 - 11:53:37 AM »
Thanks a lot.I will try both methods.
