Author Topic: What thermostst  (Read 1234 times)
Offline jason340
What thermostst
« on: December 08, 2016 - 08:56:00 AM »
70 Challenger 440, six pack. What degree thermostat do y'all use. I now have a 160 degree and the heater hardly gets warm on high and the engine gauge runs about one fourth the way up.  Thanks
Re: What thermostst
« Reply #1 on: December 08, 2016 - 10:34:18 AM »
A cooler thermostat isn't good for the engine.  Engine wear increases when the temp goes down.  You need some heat in it.  What was the factory rating for a BB?  My small block stuff came with a 192 degree stat and that's what I use.  The thermostat has nothing to do with engine overheating like some believe.  The only thing that the thermostat does is control the "lowest" temp the engine will run at.  If the cooling system pulls out too much heat, the thermostat closes to regulate the "lowest" temp.  If the cooling system isn't up to par, a lower thermostat isn't going to fix it.
I say 180 degree stat at minimum.  If the factory put a 190 degree in them then that's what I'd try. :2cents:
Re: What thermostst
« Reply #2 on: December 08, 2016 - 04:03:52 PM »
190*
Offline HP_Cuda
  • Mopar or No Car!
Re: What thermostst
« Reply #3 on: December 08, 2016 - 04:08:59 PM »
Definitely 190 as fuel atomizes the best at this temp.
Offline jason340
Re: What thermostst
« Reply #4 on: December 08, 2016 - 05:00:00 PM »
Thanks guys. I will be shopping tomorrow.  What is your thought about drilling a 1/16th" hole in the new tstat to let it burp air? I have seen that done somewhere.
Looking on line all I see is either 180 or 195, no 190.
« Last Edit: December 08, 2016 - 05:10:42 PM by jason340 »
Offline HP_Cuda
  • Mopar or No Car!
Re: What thermostst
« Reply #5 on: December 08, 2016 - 05:30:35 PM »
Re: What thermostst
« Reply #6 on: December 08, 2016 - 07:32:34 PM »
Mine is a 195*, I think?
Re: What thermostst
« Reply #7 on: December 08, 2016 - 07:39:00 PM »
Drill the hole. It makes filling the system easier. Some thermostats already have a little valve in them.
Offline jason340
Re: What thermostst
« Reply #8 on: December 08, 2016 - 07:55:02 PM »
Thanks for the replies.
Offline dfrazz
  • 1970 Cuda - 1968 Charger
Re: What thermostst
« Reply #9 on: December 08, 2016 - 08:12:42 PM »
Along with a tstat, you might want to think about a new high volume water pump.  http://www.manciniracing.com/mabhealwapu1.html
Offline jason340
Re: What thermostst
« Reply #10 on: December 08, 2016 - 09:45:14 PM »
Don't need that, the engine is running too cool now.
Offline Road_Runner
Re: What thermostst
« Reply #11 on: December 09, 2016 - 03:47:00 PM »
Others may be right about 180 degree thermostats being better for the fuel mix or engine wear, I don't know.  But the Roadrunner always liked running as cool as possible and seemed to run better on a 160 degree so that's what I always ran.  Maybe it had something to do with the meager 22" radiator it came with so I may revisit  this since I'm upgrading to a max cool 26" aluminum radiator.
1970 383 Roadrunner Tor Red
1973 318 Barracuda Mist Green
