Author Topic: What type of fastener is missing on my 71 Cuda ?  (Read 1749 times)
Offline 76orangewagon
« on: December 11, 2016 - 11:07:52 AM »
I just had Rod @ SMS Restoration restore my Emergency Brake Pedal assembly, which turned out awesome BTW, But when I went to remove the bolt on the front mounting hole (marked with red Arrow) I noticed it wasn't attached to anything, once the E brake assembly was out of the way I noticed that there was a empty rectangular hole in the sheet metal but no attaching nut for the bolt. Before I put it back together can some one help me with telling me what type of fastener goes in the hole? Thank you in advance for any and all help.
Offline 1 Wild R/T
Re: What type of fastener is missing on my 71 Cuda ?
« Reply #1 on: December 11, 2016 - 11:27:00 AM »
That square hole should have a weld nut attached to it...
« Last Edit: December 11, 2016 - 11:51:46 AM by 1 Wild R/T »
Offline 73440
« Reply #2 on: December 11, 2016 - 11:29:13 AM »
from the 1970 FSM
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline anlauto
« Reply #3 on: December 11, 2016 - 11:29:36 AM »
Yup :drunk:
« Reply #4 on: December 11, 2016 - 11:49:54 AM »
Thank you... I going to assume this style since I don't see any spot weld marks.
Offline anlauto
« Reply #5 on: December 11, 2016 - 12:07:47 PM »
That may work but it's not what was there. Wild 1 posted a picture of what would have been there.
I'm more curious about the red spring that SMS used  :clueless: I've never seen them coloured before :dunno: The firewall gaskets should also be white not black :2cents:
« Reply #6 on: December 11, 2016 - 12:21:27 PM »
Here is a picture of the assembly before I sent it out, Looks like the spring was Black.
« Last Edit: December 11, 2016 - 03:49:29 PM by 76orangewagon »
Offline anlauto
« Reply #7 on: December 11, 2016 - 12:43:40 PM »
I don't see the pictures, but I agree they should be black or natural....I've never seen red ones..... :dunno:
Offline 1 Wild R/T
« Reply #8 on: December 11, 2016 - 12:44:38 PM »
Like Alan said, the one I posted above is the correct part, but if you can get the caged nut mounted from the back side it should work fine....  I'd probably use a long bolt as a handle so you can do most of the work from the front side....
Offline anlauto
« Reply #9 on: December 11, 2016 - 12:49:44 PM »
I would hold a regular nut in the hole and weld it in solid, then run a tap through the threads and voila  you're done !
Offline 1 Wild R/T
« Reply #10 on: December 11, 2016 - 03:18:21 PM »
Yeah but the nut has to be on the back side but access to weld the back side is virtually non-existent & welding on the front side your likely to tack into the threads.... Granted you mention running a tap but sometimes welding slag is so hard it breaks a tap....   That caged nut is an easy fix...
« Reply #11 on: December 11, 2016 - 03:29:05 PM »
I ran into this issue.
Took a bolt, ran it thru the nut cage.
Opened up the hole a hair so weld had something to grab onto.
Used a weld magnet to position where I wanted it.
Sprayed the bolt with anti splatter slag.
One light tack each side.
Then tacked opposites.
Done!
Offline anlauto
« Reply #12 on: December 11, 2016 - 05:30:03 PM »
More than one way to skin a cat I guess :drunk:
