I went to install my new cam today and had to change my timing set. It had a rollmaster on it but it was a single bolt so I got a Comp cams one from summit. I used a puller to get the rollmaster gear off the crank but I can put the comp cams one on by hand. So I really don't trust the comp gear or is it normal
That it slides on by hand???
I think I will use the rollmaster crank gear with the 3 hole comp cam camshaft gear. They seem to be almost the same. Is this normal that the comp one can slide on by hand
Anyone got any advice ? Should I use it or not??
It on a 440
Cheers
