Author Topic: Help setting lifter preload  (Read 843 times)
Offline twalker
« on: December 17, 2016 - 02:39:11 PM »
New build, 300 miles on it, 505, lunati cam and hydraulic lifter package, smith bros rods, Harland sharp roller rockers, trickflow heads.  Had a 1/2 turn of preload on them but am adjusting up to 3/4 turn to see if the valve train noise settles down.
Because the motor has been running the lifters are all pumped up. When I get to zero lash and then turn 1/2 turn or to 3/4 turn the rocker is pushing the spring/valve open slightly (lifter plunger isn't compressing) This doesn't seem ok to me - help?
Thanks
Sent from my iPad using Tapatalk
« Last Edit: December 17, 2016 - 02:57:27 PM by twalker »
Offline 1 Wild R/T
Re: Help setting lifter preload
« Reply #1 on: December 17, 2016 - 02:46:19 PM »
They should bleed down, it might take 15-20 seconds but they absolutely should bleed down...
Offline twalker
« Reply #2 on: December 17, 2016 - 02:52:36 PM »
Motor hasn't run in days...
Offline 1 Wild R/T
« Reply #3 on: December 17, 2016 - 03:04:05 PM »
Yes but the oil is still trapped between the body & the plunger... If theres no pressure on the plunger the oil stays in the void... If theres significant pressure the check valve shuts & the oil is trapped making the lifter act like a solid... But if you slowly screw the adjuster down the oil will bleed..... Your only adding 1/4 turn, you should be able to add that all in one shot & the lifters should bleed down....
Offline twalker
« Reply #4 on: December 17, 2016 - 04:05:25 PM »
Ok, makes sense I think ... have them all set now to 3/4 turn, reassembling.... thx
