Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
The Body Shop
(Moderator:
Chryco Psycho
Base/Clear Respray
« previous
next »
Print
Pages: [
1
Author
Topic: Base/Clear Respray (Read 1150 times)
AMXguy
Sr. Member
Base/Clear Respray
on:
December 19, 2016 - 06:53:34 PM »
I'm not too happy with the job my painter did on the firewall and inner fenders. I want to reshoot it but I'm not sure if I can just scotch brite it and respray ? or do I have to prime it again?
I'd rather not prime again if I can avoid it I don't want to build up the thickness anymore than I have to.
Logged
1970 R/T SE Challenger
1970 Superbee
1969 S code Mach 1
1967 GTO
plumcrazzy
Jr. Member
Re: Base/Clear Respray
Reply #1 on:
December 19, 2016 - 08:57:49 PM »
Are you unhappy with the base coat or clear coat? Either way, let the surface cure well then just scuff and reapply the color or clear coat. No need to reprime but make sure you follow the manufacturers directions on how soon to recoat.
Logged
AMXguy
Sr. Member
Reply #2 on:
December 19, 2016 - 09:59:36 PM »
He missed a few spots and didn't get the clear on too good. kind of sloppy actually.
It's been about a month and it will be another before I'm ready to do it. I'd think that would be long enough to avoid any lifting. not much info on the can.
Logged
1970 Superbee
1969 S code Mach 1
1967 GTO
GoodysGotaCuda
Sr. Resident
Reply #3 on:
December 19, 2016 - 10:34:41 PM »
Scuff clean and shoot.
Logged
Build Page:
Goody's 'Cuda Build Page
1976 Dodge Warlock
Wheel & Tire Specs:
Link
lulurocks
Jr. Member
Reply #4 on:
December 20, 2016 - 09:29:35 AM »
Quote from: GoodysGotaCuda on December 19, 2016 - 10:34:41 PM
Use 3m scuff it gel And a scotch brite till there is no shine , scuff it and red and grey pads work well and dont cut thru color or u have to spot prime. If its a large spot ....
Scuffit link:
http://multimedia.3m.com/mws/media/157743O/3mtm-scuff-ittm-paint-prep-gel-flyer-pn-06013.pdf
Last Edit: December 20, 2016 - 10:51:43 AM by lulurocks
Logged
js29no
Sr. Member
Reply #5 on:
December 20, 2016 - 03:09:53 PM »
Only if you hit bare metal will you have to re-prime. after several months you should be fine on re-coat time.
Logged
AMXguy
Sr. Member
Reply #6 on:
December 20, 2016 - 11:03:55 PM »
thanks guys
Logged
1970 Superbee
1969 S code Mach 1
1967 GTO
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
The Body Shop
(Moderator:
Chryco Psycho
Base/Clear Respray
