Author Topic: Edelbrock carb gurus  (Read 2977 times)
Re: Edelbrock carb gurus
« Reply #15 on: December 23, 2016 - 09:35:39 PM »
 :burnout:   :cooldancing:
Offline Uncle Barry
« Reply #16 on: December 23, 2016 - 09:47:24 PM »
It would stumble with the stock squirters in it so I put .043 in them. It probably too fat on the hit now but it made a huge difference. It runs the best with the pink springs. I can't remember what they are rated for and I think I have the 1449 rods with the .116 jets in it. I tried the 1444 rods but the car started feeling lazy.
« Reply #17 on: December 23, 2016 - 10:02:36 PM »
you are on the right track
Offline Uncle Barry
« Reply #18 on: December 23, 2016 - 10:10:06 PM »
If I were to try AVS carbs, what would you recommend? 750 or 800?
« Reply #19 on: December 23, 2016 - 10:17:07 PM »
I doubt it would make a lot of difference either way you will have enough CFM at 1500 vs 1600
Offline Uncle Barry
« Reply #20 on: December 23, 2016 - 10:22:22 PM »
 :2thumbs::
Offline 734406pk
  • Andy
« Reply #21 on: December 24, 2016 - 01:32:17 AM »
You may want to consider an AFR gauge to assist in carb tuning...Seat-of-the-pants tuning does work but it is expensive and very time consuming. Having AFR numbers in problem areas is incredibly helpful. Beautiful car BTW! :2thumbs:
Offline rUNCHARGER
« Reply #22 on: December 24, 2016 - 12:07:28 PM »
An AFR gauge does speed up tuning but I find I get them just as close by plug reading and driveability. It sounds like the OP has a pretty good handle on it. I don't think you'll gain enough going to AVS to make it worthwhile, if you didn't have the AFB's then I would get the AVS. I was impressed the stock 1407 jetting was right on for my friends 572 with a Mod Man and similiar camshaft, we used 1-1 linkage though.
Sheldon
« Last Edit: December 24, 2016 - 12:09:28 PM by rUNCHARGER »
Offline Uncle Barry
« Reply #23 on: December 24, 2016 - 12:24:44 PM »
Sheldon
stock jetting was too lean on mine Sheldon. I use progressive linkage because 1:1 was too touchy for my liking. It was like a light switch with the pedal. It was either on or off. Thank you all for your input and comments. Greatly appreciated
Offline 734406pk
  • Andy
« Reply #24 on: December 24, 2016 - 04:45:22 PM »
Sheldon
 :iagree: Posting AFR numbers helps determine rich/lean issues without actually being there IMO. The OP may possibly be at, or close to, the limits of the AFB's capability.
Offline Flatdad
« Reply #25 on: February 01, 2017 - 10:41:23 AM »
Uncle Barry, I've got so many questions about your setup! My 528 is all iron 10:1 with less cam and stock int and exh manifolds. Struggled all last year with it. Do you run a regulator between the pump and the carbs? Do you run a Carter mechanical pump? Dual 1407's here as well...
'70 Road Runner-B7 383 Auto, now with more cubes
'97 Ram 1500 Sport 4x4-Bright Red 318 magnum
'67 Belvedere II-Dark Blue 318 Auto, now owned by my brother
'73 Challenger Rallye-B5 318 Auto, had a 360 in it, SOLD :(
'42 Harley Davidson 42WLA-U.S. army green 45ci flathead
'71 Challenger R/T-B5 383 Auto, now 400 powered and rusty!
'86 W100-Yellow 318-2bbl 4x4 4spd, off road toy
'06 Magnum R/T AWD-Red 5.7 Auto, daily driver
Offline Uncle Barry
« Reply #26 on: February 02, 2017 - 02:39:27 PM »
I do run a regulator. I also run a 140gph electric pump. The car runs really well and I think it will run better with more tuning. I pretty sure it will go a 10.50 or 60 when I get time to sort it out. But I'm thinking of putting a tunnel ram on it and having fun lol
