Author Topic: 440 Spark Plug Wire lengths  (Read 1286 times)
Offline Giveitawack
    • ebay
« on: December 25, 2016 - 04:47:16 AM »
When I open a box of spark plug wires there is no diagram where the wires go. I can figure out that the longest should be #7 and the shortest #2, but all the others? Is there anybody out there that has a list of wire lengths and cylinder numbers? :clueless:
« Last Edit: December 25, 2016 - 06:26:26 AM by Giveitawack »
Offline usraptr
Re: 440 Spark Plug Wire lengths
« Reply #1 on: December 25, 2016 - 12:00:45 PM »
It's just a process of trial and error.  Since the distributor is on the passenger side the longer wires go to the drivers side and the shorter to the passenger.  Pick the two longest wires.  Longer of the two to the Drivers side, ie #7.  Next two longest and repeat. Longer to #5 and so on.  Good luck and Merry Christmas.
(Edited 8-1-17)
Offline Beekeeper
« Reply #2 on: December 25, 2016 - 01:05:11 PM »
I like to get the custom length sets. It takes a special crimp tool to get them perfect but it's worth it. I love the look of the wires when each one is just the perfect length.
Offline twalker
« Reply #3 on: December 25, 2016 - 02:23:35 PM »
Same here.  Crimping was straight forward - was concerned before buying, but not now.
Sent from my iPad using Tapatalk
« Reply #4 on: December 25, 2016 - 11:17:26 PM »
I always use the shortest wire that will reach & use the long ones last cutting them to length
