Author Topic: New block , can make wedge or hemi  (Read 1233 times)
Offline cudabob496
Re: New block , can make wedge or hemi
« Reply #1 on: December 26, 2016 - 04:10:55 PM »
good design.
before, if lose lifter, lose all oil to mains.
happened to me
2011 Kawasaki Z1000
Offline Road_Runner
« Reply #2 on: December 28, 2016 - 12:13:59 AM »
Just WOW!  Not cheap, but like they said should last decades of use on the street, so you'll only need to buy one.   I'd be curious to see the difference in building a large hemi vs large wedge with the best heads, etc.  I know the valve train would cost more for the hemi,
maybe pistons, too?
1970 383 Roadrunner Tor Red
1973 318 Barracuda Mist Green
Offline cudabob496
« Reply #3 on: December 28, 2016 - 01:56:43 AM »
maybe pistons, too?
for same hp, Hemi might cost 50% more
2011 Kawasaki Z1000
Offline rUNCHARGER
« Reply #4 on: December 28, 2016 - 11:06:16 AM »
Nope: Once you try making a wedge run hard it isn't much cheaper than going Hemi to start with. Pistons may be a bit cheaper for a wedge, heads are within a few hundred dollars and Hemi heads don't need porting. Rocker gear is within a few hundred, everything else is the same. I'd say the difference is within $1000 when you are using non-stock parts.
Sheldon
Offline HP_Cuda
  • Mopar or No Car!
« Reply #5 on: December 28, 2016 - 05:23:31 PM »
Glad to see there are alternatives!!!
 :2thumbs:
