Author Topic: 7260 vs 7290  (Read 994 times)
Offline mjb765
7260 vs 7290
« on: December 27, 2016 - 10:45:30 PM »
Had an 8 3/4 489 center section built and the builder installed a 7260 yoke instead of the requested 7290. This car will be street driven with occasional spirited launches and driving (it's a 4 speed). Mostly stock 383 with a mild cam. Should I switch the yoke or am I OK with the 7260????
Thanks
Re: 7260 vs 7290
« Reply #1 on: December 27, 2016 - 11:02:48 PM »
Should be OK , I would use the conversion joint though so the shaft has 7290 on both ends
Offline anlauto
Re: 7260 vs 7290
« Reply #2 on: December 27, 2016 - 11:21:14 PM »
I was going to ask what size the driveshaft was.... :iagree:
Re: 7260 vs 7290
« Reply #3 on: December 28, 2016 - 09:13:56 AM »
I've done 4500 rpm launches with slicks on a prepared track with 7260 u-joints, so they are up to it. I tried to buy the most reputable brand I could find and got them with solid crosses, not drilled for lubrication.  I have broken them, but that typically happened when I got too much lift from the suspension and exceeded their operating angles. Then they grenade in spectacular fashion.
Offline mjb765
Re: 7260 vs 7290
« Reply #4 on: December 28, 2016 - 09:18:33 AM »
That was the plan.....the shaft has a 7290 in the back now. I didn't check what size the front was.
Thanks all for the info.... :ylsuper:
« Last Edit: December 28, 2016 - 09:27:06 AM by mjb765 »
Offline rUNCHARGER
Re: 7260 vs 7290
« Reply #5 on: December 28, 2016 - 11:01:03 AM »
My 340 Challenger driveshaft was 7260 in the front and 7290 in the back from the factory so you won't be any weaker than that anyway.
Sheldon
