Author Topic: anyone shorten an ebody 8 3/4 axle?  (Read 4529 times)
Offline dave73chally
« on: December 29, 2016 - 03:05:03 PM »
Has anyone shortened their e-body 8 3/4 axle to fit a wider tire? I have a stroker 440 but it's only going to see street use. I don't have 2k at this time to throw around for a new dr. diff dana 60 combo. Thinking about having the stock axle shortened so I can run a 10" wide rim with a spring relo kit for relatively cheap for the time being. Thoughts?
73 Challenger
Offline crash340
Re: anyone shorten an ebody 8 3/4 axle?
« Reply #1 on: December 29, 2016 - 03:34:48 PM »
Try and find a B Body 8.75 with axles, a lot less pain
Greg
73 Cuda
Brisbane, Australia
« Reply #2 on: December 29, 2016 - 03:54:52 PM »
Been trying...anyone have any leads on one in the New Jersey area?
73 Challenger
« Reply #3 on: December 29, 2016 - 05:54:42 PM »
Use the spring relocation kit and buy rims with backspace to get the job done. I have a stock width ebody rear axle with 315's.
« Reply #4 on: December 29, 2016 - 06:50:03 PM »
What spring relo kit do you have? Dr diff only has the 1" in stock. What size wheel, backspace and tire are you running?
73 Challenger
« Reply #5 on: December 30, 2016 - 08:23:02 AM »
I used Cass's 1.5" spring relocation kit, which has the same front hanger as the 1" just a bigger offset rear shackle set. The rims I'm using have, I think, about a 6 5/8" backspace. I can take it off and measure for you if you decide to go that route.
« Last Edit: December 30, 2016 - 05:56:36 PM by dodj »
Offline soundcontrol
« Reply #6 on: December 30, 2016 - 10:05:08 AM »
Interesting, any pictures of that?
/ Ken
topic=108917.new#new
« Reply #7 on: December 30, 2016 - 05:55:58 PM »
I could take some. What would you like?
Offline KillerBee
« Reply #8 on: December 30, 2016 - 09:41:23 PM »
Just installed a 1967 B body rear in the wife's R/T Challenger last fall with Dr. Diff's 1" offset bolt in kit.
Here's some info:
All B body leaf spring perches are 44" apart
The 1966-67 B body rear is the narrowest that will be a direct bolt in but are difficult to find.
The housing is 54 1/4" flange to flange
1968-70 B body rear ends are much more common and will also work great but is just a wee bit wider at 54 15/16" flange to flange.
FYI your current E body rear is 56 31/64" flange to flange and the perches are 46" apart.
-B body 8 3/4 housings show up often on E-bay.
-Keep checking your local Craigslist, B body 8 3/4 rear ends show up often around my area.
-A local Mopar swap meet might have some too.
*Take a tape measure and make sure whatever rear end your looking at is correct.
If buying off the internet I would just try to find and buy a bare B body housing as it would be cheaper to ship.
I suggest you buy brand new(stronger) axles with pressed on bearings from Dr. Diff.
You can re-use your Challenger's current rear brake setup.
The rear end install on my wife's R/T was a super easy bolt in deal.
She wanted to keep the car's old school 15x10 rear Centerlines (that have a terrible 3 5/16" back spacing) because that is what her late father put on the car when he restored it in the late 80's.
Tires are 275/60-15.
In the top picture you can see just how far the tires stick out with the stock E-body rear end.
Second and third pictures are with the B body rear end installed with the same rims and tires completely tucked under the car.
« Last Edit: December 30, 2016 - 11:16:53 PM by KillerBee »
« Reply #9 on: December 31, 2016 - 07:01:36 AM »
Maybe some from the rear that shows how much space you have inside, and how close the tires are to the quarterpanel?
/ Ken
« Reply #10 on: December 31, 2016 - 01:27:29 PM »
OK
I didn't mention it but I of course had to grind off the original perches and weld on new ones in the moved in position.
« Reply #11 on: January 01, 2017 - 07:47:54 AM »
« Last Edit: January 01, 2017 - 07:52:36 AM by dodj »
« Reply #12 on: January 01, 2017 - 02:17:21 PM »
Thanks Scott! That looks great, nice and fat. Plenty of room on either side also. On my list now for future upgrades.
/ Ken
Offline Road_Runner
« Reply #13 on: January 01, 2017 - 04:28:39 PM »
OK
Wheels & tires look great, can you share the exact type of wheels (look like Torq Thrust M's?), their sizes, backspacing along with the tire sizes front & back?  Also, any clearance issues you have including any cutting of braces, etc. for the offset kit?
Thanks, Jim
1970 383 Roadrunner Tor Red
1973 318 Barracuda Mist Green
« Reply #14 on: January 01, 2017 - 05:57:12 PM »
Forgot, I guess a stock type swaybar will be an issue?
/ Ken
