Wheels & tires look great, can you share the exact type of wheels (look like Torq Thrust M's?), their sizes, backspacing along with the tire sizes front & back? Also, any clearance issues you have including any cutting of braces, etc. for the offset kit?
Thanks, Jim
You are correct, they are torq thrust M's. 17x10.5 BS-6 5/8" in the rear, 17x9 BS-6" in the front. The hub bore needs no machining, often a problem when fitting mustang rims to mopars. I have a 25mm spacer behind the front wheels to get me a 5" BS for proper steering clearance.
The tires are Nitto NT-05 315ZR35 rear 255ZR40 front
I have a '73 Challenger so no cutting of braces to fit the 1.5" offset kit. I saw a picture of Katfish's '70 Challenger and he had to cut some bracing off of a 70 rear valence.
72bluNblu and Goodysgotacuda helped me significantly in advise and getting the right parts to make them fit.
