Author Topic: 71 barracuda steering box  (Read 1234 times)
Offline MoparCuda340
« on: December 30, 2016 - 07:55:47 AM »
We just bought (our first RUNNING mopar) a 71 cuda and I'm sure I'll be dropping plenty of questions on this form. Reading around you guys are molar geniuses. Anyway the power steering box is absolutely pouring steering fluid from the top, right where the steering shaft enters. After reading around it seemed much easier and just about as cheap to buy a new box rather than rebuild. But as I surfed the web I found there is a huge variance in price. One from Oreillys for 108 and others from mopar sites for 400 to 600. Any suggestions on the boxes? I don't wanna buy the cheapest but I can't afford 600 bones right now and want my dad to be able to drive the car soon. Thanks
Offline mopar jack
Re: 71 barracuda steering box
« Reply #1 on: December 30, 2016 - 10:31:20 AM »
If it's just leaking at the input shaft you can replace the seal without pulling the box and drive it now.
« Reply #2 on: December 30, 2016 - 10:46:11 AM »
Steering boxes differ but check out this video.
! No longer available
Offline mopar jack
« Reply #3 on: December 30, 2016 - 12:33:31 PM »
On a mopar box you only have to pull the top seal. just pry it out as in the video and replace with a deep socket to drive it in. The hard part is driving out the roll pin to disconnect the steering column shaft from the input shaft.
« Reply #4 on: December 31, 2016 - 06:39:39 PM »
If you ARE GOING TO REPLACE it I would look at Firm Feel or Steer & Gear stage 3 boxes
Offline EB3-GranCoupe
  • BP23 U0B
« Reply #5 on: December 31, 2016 - 06:55:32 PM »
Had mine redone, and upgraded by Firm Feel, very pleased.  Give them a call:
http://www.firmfeel.com/e_body_mopar_power_steering_box_rebuild.html
