Author Topic: Mopar Big Block Parts Lot  (Read 532 times)
Offline Claudia
« on: January 05, 2017 - 11:21:00 AM »
Mix of new and used Mopar big block parts lot:
Mopar Performance Air Cleaner Base Plate
Mopar BB Misc Hardware
Mopar BB Valve Cover Gasket Set (rubber)
Mopar BB Valve Cover Gasket Set (cork)
Mopar BB Cylinder Head Springs, Retainers & Exhaust Valves Set
Rocker Arm Shims (vertical and horizontal)
Mopar BB Chrome Valve Cover Hold Downs
Mopar BB Coil w / Mounting Bracket
Radiator Cap
Mopar BB / 727 Kick Down Linkage
Mopar BB Timing Chain Cover
Mopar BB Water Pump Gasket
Mopar BB Camshaft
BB Fan Clutch
Mopar BB Fuel Pump Pushrod
Mopar BB HP Exhaust Manifold Heat Riser
66 - 72 B-body / 66 - 73 C-body / 70 - 74 E-body LH 440 Engine Support Bracket
Mopar BB Fuel Pump Gaskets
Mopar BB Flexplate
Mopar BB Rear Main Seal Retainer
Mopar BB Oil Pump Shaft
Mopar BB Oil Pump
Fram Oil Filter
Mopar BB Oil Pickup Tubes
$450
