Author Topic: Valley pan install  (Read 1048 times)
Offline Jamie
Valley pan install
« on: January 05, 2017 - 10:25:08 PM »
Ok,first big block build. I am installing edelbrock performerintake onto aluminum heads. I purchased a sheet metal valley pan and I just can't trust a bead of silicon that long down the sides of pan where it meets heads. Any re-assuring "it won't  leak " tips? I foresee an oil leak and a vacuum leak in my future.
 This is than than just butts up against bottom of heads, still using normal paper gaskets for intake to head.
« Last Edit: January 10, 2017 - 09:17:09 PM by Jamie »
I will finish a project.I will finish a project. I will finish a project.
70 barracuda plum crazy
( current goal is to keep just one car) AND FINISH IT!
08 charger r/t  w/road & track package
2011 silverado
Offline 73440
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline Jamie
Re: Valley pan install
« Reply #2 on: January 05, 2017 - 10:52:01 PM »
I cannot tell you how much I searched for an article that thorough. Thank you much!
2011 silverado
Offline 73440
« Reply #3 on: January 06, 2017 - 07:16:55 AM »
http://www.hughesengines.com/TechArticles/productinstructionsheets.php
 They have a lot of other articles like that here as in anything read through it and decide what is right I don't know anything personally about their work .
Always do your research , comparing to the FSM is always a good idea.
The information and encouragement I get from the people on this site have made me unafraid to try to fix almost anything on the car.
67 440
72 413 / 727
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline headejm
« Reply #4 on: January 06, 2017 - 03:26:55 PM »
I live about 5 miles from the Hughes shop. They have been in business for many years. Mostly, if not all, Mopar engine stuff. As in the financial world...past performance is not an indicator of the future. Always do your own research and make an educated decision!
Offline Mopar Mitch
« Reply #5 on: January 06, 2017 - 11:43:19 PM »
Jamie -- with the metal valley pan gasket, just add the Fel-Pro "supplementary fiber gaskets" (4 pcs included in the set)... intended for aluminum mflds, as well as older engine rebuilds.
« Reply #6 on: January 08, 2017 - 08:11:46 PM »
I only use the extra paper gaskets between the pan & heads to prevent oil leaks with all 4 it is real tough to get the intake on
