e-pay tranny
Author Topic: e-pay tranny  (Read 2208 times)
Offline A110235
  • '71 Challenger JH23G1B
e-pay tranny
« on: June 27, 2005 - 03:48:32 PM »
Check out what I scored off of e-gouge for $50 (plus shipping)!  OD A-833 with shifter.  I owe Chryco a big thanks for the input and advice with my questions.  :beer:  I hope that it didn't get too dinged up during shipping.  Now I just gotta start searching for the parts to make it all work.  Anyone have any luck with a hydraulic clutch release?  Or should I just stick with the fork?
Nashville, TN         Member since October 09, 2004
Re: e-pay tranny
« Reply #1 on: June 27, 2005 - 07:41:08 PM »
I have used both the McLeod & Tilton hyd clutch release brgs , both work , I like the McLeod better though
 Glad I could help so far
Offline 1973challenger360
Re: e-pay tranny
« Reply #2 on: June 29, 2005 - 02:06:07 PM »
 :thumbs: :thumbs: :thumbs: :thumbs:  what did shipping run that was a great price.
1965 barracuda. Was 273/2 904 car had 440 360 in plans
1996 Dodge 1500 ST 5.2 Np3500 4x2 club cab short bed
2008 Veracruz AWD Limited     I pay she drives
Offline A110235
Re: e-pay tranny
« Reply #3 on: June 29, 2005 - 10:56:19 PM »
It was shipped UPS for about $80.  At first the guy wanted to freight it to me and it was going to cost like $250.  I am glad that it worked out the way it did.  I got lucky on the auction price.  I still don't believe that I was the only person who put a bid on it.
Offline b5blueaar
  • Mad Max Cuda
Re: e-pay tranny
« Reply #4 on: June 30, 2005 - 02:08:11 PM »
is that an 18 spline or 23 spline?
If I had seen it you would not have been the only bid.
You got very lucky. If its an 18 spline you were doubly lucky. :wave: :beer:
Offline cuda
  • 1970 340 Cuda, pistol grip 4 speed,3:91 sure grip
Re: e-pay tranny
« Reply #5 on: June 30, 2005 - 04:33:52 PM »
Sweet deal, your going to like that. I love my O.D. I run a macleod clutch and its done well for me.  :burnout:
Re: e-pay tranny
« Reply #6 on: July 01, 2005 - 12:11:34 AM »
OD s are all 23 spine trannys
Offline A110235
Re: e-pay tranny
« Reply #7 on: July 18, 2005 - 12:10:33 PM »
I am now trying to find a small block bellhousing.  I think that Chryco said that the 5.12" bearing retainer can be machined down to 4.80."  Since the OD trans has the 5.12" bearing retainer and the 4.16" bolt pattern, can I only use a bellhousing with either the 4.80" or 5.12" bearing retainer size?  Will the bellhousing with the 4.35 bearing retainer not work because of the small 3.70" bolt pattern size?
« Last Edit: July 18, 2005 - 12:12:04 PM by A110235 »
cudahob
Re: e-pay tranny
« Reply #8 on: July 18, 2005 - 01:25:45 PM »
I got one (bellhousing), think it's off a 340 Duster. Gota check the numbers...
Offline A110235
Re: e-pay tranny
« Reply #9 on: July 18, 2005 - 09:48:30 PM »
Thanks cudahob!  If I can make it work with my OD trans I may be interested it buying it.
Re: e-pay tranny
« Reply #10 on: July 19, 2005 - 12:58:27 AM »
true the early "small" 4.35 belhousing will not work unless you want to machine the hole out to 4.80 or 5.12 diameter
cudahob
Re: e-pay tranny
« Reply #11 on: July 19, 2005 - 09:56:05 AM »
I'll keep it for ya, just PM.
Offline A110235
Re: e-pay tranny
« Reply #12 on: July 19, 2005 - 11:56:36 AM »
Will machining the 4.35 out to 5.12 weaken it too much?
Re: e-pay tranny
« Reply #13 on: July 19, 2005 - 12:15:04 PM »
no but you need to watch the fork pivot mount holes
Offline A110235
Re: e-pay tranny
« Reply #14 on: July 20, 2005 - 01:26:49 AM »
How critical is the dimension when the bell housing gets machined out to 5.12“?  Is the bell supposed to be pressed on and then secured with the 4 bolts to the main body?  Or is it ok to go out to like 5.25” and give it some room?
