Author Topic: Tried to install a holly  (Read 1073 times)
Offline purple1
  • Worlds first e-body trailer. Member since 3/10/05
« on: June 27, 2005 - 04:57:33 PM »
I tried to install a Holly 750 on Sunday.
My stock 383 manifold hit the linkage.  :banghead:
I have ordered a spacer from Summit, I hope it
will solve my problem. Has anyone else had this
problem? And will i have any other problems?
I have ordered a 1" spacer w/hardware.
Will I need any other parts?
Worlds first e-body trailer.    Severna Park, Maryland
Re: Tried to install a holly
« Reply #1 on: June 27, 2005 - 05:29:30 PM »
Yes those problems do exist.  :stomp:  I put a Holley double pumper on my Edelbrock intake and had to do some "modifications". Let's just say I had some boring away to do at the intake manifold.  ::)  The only thing I worry about a spacer is if your hood will still close. It might be tight. Heck, I haven't seen your car yet, maybe I can see it this week if you can put up with me?
Offline hemi71
« Reply #2 on: June 27, 2005 - 05:33:45 PM »
Do you have the thottle cable adapter? That makes the throttle cable install a lot easier, otherwise you will be cobbing up something.
Offline purple1
« Reply #3 on: June 27, 2005 - 05:52:41 PM »
Mike, come on over! I think there is plenty of room under there.
hemi71,It already has the cable adapter. I knew I would need that.
But will I have to change anything else?
« Reply #4 on: June 27, 2005 - 07:47:17 PM »
normally you will have to change the coil mounting position , you will also need longer studs to bolt the carb down , with the stock intake you should have lots of hood clearance , you can use a 1/2 spacer & gain enough clearance as well if needed , check to make sure all the throttle plates open fully as you are bolting the carb on , sometimes there is interference
Offline purple1
« Reply #5 on: June 28, 2005 - 12:40:06 PM »
Thanks CP. I thought the coil woul need to be moved.
The spacer I ordered comes with gaskets and longer studs for mounting.
I will try to install again this weekend.
« Reply #6 on: June 28, 2005 - 11:07:34 PM »
 :thumbs:
