Author Topic: Okay One More Time  (Read 1456 times)
Offline 04lbram
Okay One More Time
« on: June 27, 2005 - 06:25:52 PM »
Okay guys, well I've changed my mind for now and I have decided to make my car more of a street cruiser and highway driving. Anyways, thinking about switching out the carb to something different. I currently am leaning toward an Eddy Thunder Series Carb 800 cfm carb but, I know everyone has their preferences on Holley. I'm not proficient at tuning carb so would the Holley or Eddy be better for highway driving because most shows and meet I would drive too is at least 100 miles away. I also thought about a 650 but, I know that would be under carbed as the 2x cid rule so 383x2 is 766 cfm minimum especially have a bored out motor
Here's my current setup:
69 383 bored .010 over
HP Manifolds
Road Runner Cam
Edelbrock Performer Dual Plane Intake
2 1/2 Exhaust I believe
Taylor 8mm Wires
MSD Coil
Electric Fan
Edelbrock Performer 750 cfm carb
Stock Bottom End
3.55 gears
B&M Shift kit with Shifter
Stock Converter
Let me know what you guys think I should change out in addition to the carb without tearing into the motor.
71 Dodge Challenger R/T Clone; 383 Big Block with a few goodies and good ole 14" Slot Rims
Re: Okay One More Time
« Reply #1 on: June 27, 2005 - 07:51:35 PM »
I doubt you will see a significant gain going from a Eddy Performer to a Eddy Thunder carb especially if you are not Tuning the carbs
 , the size of the carb really has little effect on milage , if the carb is tuned properly you should get decent milage , , often using annular boosters increases the effeciency of the carb by mixing the fuel better
Offline 04lbram
« Reply #2 on: June 27, 2005 - 09:02:43 PM »
"often using annular boosters increases the effeciency of the carb by mixing the fuel better" Chryco but, I'm a little lost with what you said. Please keep in mind I'm a newbie so if you could explain everything I need to know about carbs that would be great or if some of you other folks want to enlighten me.
Offline GoMango
« Reply #3 on: June 27, 2005 - 09:12:31 PM »
That's about the same 383 setup I have in my Coronet. The main difference is I still have a stock 4bbl intake on it. Just a quick note on the carbs, I have a 650 Edelbrock on it and I had a 780 Holley on it for a while. The car actually got better miieage w/ the 780 and had a lot more git-up.
70 Challenger R/T
(Back on the road--1st time since '96)
Offline 04lbram
« Reply #4 on: June 27, 2005 - 09:40:10 PM »
Thanks for the heads up. I wouldn't mind going to a Holley since my dad has a 700 CFM Double Pumper on his 340 Charger but, I don't think it would adapt well to an Edelbrock Intake.
Offline GoMango
« Reply #5 on: June 27, 2005 - 10:39:54 PM »
It should fit on the Eddy intake but a double pumper might be a little much on an automatic car. Vacuum secondary Holley would work better.
70 Challenger R/T
Offline EVIL72
« Reply #6 on: June 27, 2005 - 10:48:04 PM »
 I'd go with a Holley vacuum secondary on your setup.
ROB
1972 Dodge Challenger 340ci
1970 Pro Street Duster (Under Construction)
