Author Topic: Six Pack center carb  (Read 3427 times)
Offline 440Mag
« on: January 12, 2017 - 04:18:41 PM »
Why there is that bowl vent in 440+6 center carb assy?
JS23V
Finland
Offline larry4406
Re: Six Pack center carb
« Reply #1 on: January 12, 2017 - 06:18:24 PM »
I think that is 69-70. 71's have a nipple with hose to a breather on passenger valve cover.
The "why" I will leave to others.
Offline 734406pk
  • Andy
« Reply #2 on: January 12, 2017 - 08:53:38 PM »
The bowl vent was there for to meet the primitive evaporative emissions requirement of the time.
Offline 440Mag
« Reply #3 on: January 13, 2017 - 05:51:44 AM »
Okay, thanks.
My center carb bowl is bad, and i need to replace it. Should  A normal bowl work without that extra hole and lever?
JS23V
Finland
Offline mopar jack
« Reply #4 on: January 13, 2017 - 11:44:20 AM »
The bowl will have to be able to accommodate the accelerator pump in the bottom. Outboard carb bowls won't work because of this. So if you find a correct replacement bowl it will most likely a have vent provision.
Offline 734406pk
  • Andy
« Reply #5 on: January 13, 2017 - 08:19:30 PM »
I agree, I'm looking around for a 2300 carb body to confirm, but i believe if you have a standard Holley 4150 float bowl w/ an acellerator pump you should be ok.
« Last Edit: January 30, 2017 - 01:03:07 AM by 734406pk »
Offline mopar jack
« Reply #6 on: January 13, 2017 - 09:00:07 PM »
you can use an outboard bowl if it has the 4 bolt flange for the accelerator pump. You would have to drill the orifice and install a check ball.
Offline 440Mag
« Reply #7 on: January 14, 2017 - 06:10:42 AM »
Or can I buy this for center?
https://www.summitracing.com/int/parts/hly-134-103/overview/
JS23V
Finland
Offline mopar jack
« Reply #8 on: January 14, 2017 - 11:24:46 AM »
It looks like that one should work. It list as a bowl for a primary 2300 carb.
Offline 440Mag
« Reply #9 on: January 14, 2017 - 11:31:46 AM »
Okay, thanks!
And sorry, I didnt noticed that 440+6 sticky topic above  :-[
JS23V
Finland
Offline 734406pk
  • Andy
« Reply #10 on: January 14, 2017 - 08:12:38 PM »
