Author Topic: 71 cuda gas pedal position?  (Read 1215 times)
Offline wantone
  • (O O {]{]{]||[}[}[} O O)
« on: January 13, 2017 - 05:59:20 PM »
I have an automatic car with a console.   I have replaced my throttle cable with a Lokar setup and don't recall how the pedal sat before.  Ideas?
Want one?  Got one! ... finally
Re: 71 cuda gas pedal position?
« Reply #1 on: January 13, 2017 - 10:08:11 PM »
Not really sure what you are asking here, but, adjust the throttle linkage so when the carb is fully 'wide open', the pedal can't go any further. So you don't 'torque' the throttle plates, when they can't open any further.
Offline wantone
« Reply #2 on: January 13, 2017 - 11:55:03 PM »
The Lokar cable was an insanely long cable.   I now have the ability to have my pedal float above the floorboard or sit on it.   I am wondering how I should go about setting it?
1- Do I go ahead and lay the pedal against the floorboard and then open the throttle all the way and leave 0 play between the two?
2- Do I make the gas pedal even with the brake pedal and then leave the throttle all the way closed and set it there?
Offline 73440
« Reply #3 on: January 14, 2017 - 07:16:07 AM »
Or like I told Courtney Force at the track one day, " Cut a hole in the floorboard so you can mash the gas pedal even further and go faster"
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
« Reply #4 on: January 14, 2017 - 08:28:01 AM »
Option 1.
You just don't want the gas pedal ,say a half inch off the floor with the throttle plates already fully open. I f you have that situation, you are going to try to mash the pedal to the floor but the throttle plate shaft can't turn anymore. So it starts to bend.
Offline wantone
« Reply #5 on: January 15, 2017 - 04:37:26 PM »
My dude!  Thanks again - again- again dodj! :cooldancing: :clapping: :woohoo: :jumping:
