Author Topic: Wiring for standard gauges  (Read 670 times)
Offline Just Challenger
  • Newbie
« on: January 13, 2017 - 08:55:10 PM »
70 challenger
 Hello everyone. Ive look all over google images and here for a picture of the back of the standard gauges withd the wires and have only found the rally gauges. I rewired my dash and have the little blue harness for the back of the gauges. The main problem is the fuel gauge and temp gauge. I put the violet wire on the violet for the temp and same with the dark blue for the fuel. The temp did not work the last time i had it running and the fuel worked but i dont think it was showing the right amount. I have a good ground for the sending unit and the temp thing that screws into the engine was just replaced. Someone on another thread suggested to run a ground to the wire that pushes onto the temp thing and the gauge should go all the way up. I did and nothing happened. I would appreciate any information you have. Thank you
