Looking for an R3 small block or equal
Author Topic: Looking for an R3 small block or equal  (Read 1034 times)
Offline Mopar Thunder
« on: January 14, 2017 - 06:18:16 PM »
Found out bad news that my block is no good.  It was bored out too much.  :swear: Trying to swallow what went down but there is no other choice except to start with a sufficient block that will handle my application. I would be interested in it also if it has a rotating assembly. Not sure of all the specs needed yet.
Offline 1 Wild R/T
Re: Looking for an R3 small block or equal
« Reply #1 on: January 14, 2017 - 06:47:00 PM »
This was posted on another site
This is a new unused Mopar Performance Cast Iron R3 Race Block part # P4876791AD. Specs of the block per Mopar Performance are as follows:
• Process-controlled castings utilizing high-strength cast iron
• 100% CNC machining with full statistical process control
• Thick deck surface and six-bolt cylinder head attachment for improved sealing and reliability
• 9.200” deck height
• Tappet angle 59°
• Thicker main webbing and pan rail for improved rigidity
• Four-bolt mains - ductile iron
• 2.50” main journal diameter
• Machined for "LA" and Magnum head oiling, as well as engine mounts
• Stock small block cam tunnel so you can use any LA cam you like
• Wet sump oiling
The block casting number is P4532907. This is an unused as delivered R3 block ready to build into a large HP small block.
Price is $3,000 plus shipping
  procketrichard@hotmail.com
« Reply #2 on: January 15, 2017 - 01:01:16 PM »
• Tappet angle 59°
• Wet sump oiling
Thanks I'll look into it. I was hoping to get into a 48 degree tappet angle but we'll see.
