Author Topic: U joint girdles  (Read 790 times)
Offline 7212Mopar
U joint girdles
« on: January 17, 2017 - 03:30:31 PM »
I am shopping for new u joints (7260) and came across some U joint girdles that Moroso makes. It is supposed to be used in lieu of straps or u bolts. They look beefy but are they really necessary as the cost is the same as two u joints.
1973 Challenger Rallye, AT with 1971 340
2012 Challenger SRT8 392 YJ,  6 spd
Re: U joint girdles
« Reply #1 on: January 17, 2017 - 09:38:07 PM »
The straps & bolts never seem to be a weak / failure point
Offline 7212Mopar
Re: U joint girdles
« Reply #2 on: January 24, 2017 - 01:15:00 AM »
Tanks. Got me some Yukon 7260 straps.
Re: U joint girdles
« Reply #3 on: January 24, 2017 - 11:51:24 AM »
The only time I've seen girdles be of benefit is if your rear suspension is generating excessive lift at launch. They will help keep the caps on the joints in this case, but otherwise I can't say I've ever broken the stock straps.
