Author Topic: Picture of installed Tanks Inc fuel pump?  (Read 2865 times)
Offline dakota
« on: January 19, 2017 - 09:21:56 PM »
I have one of the Tanks Inc PA-2 fuel pumps to mount in the new fuel tank for my 70 Challenger.   I still have to test fit everything, but I was hoping someone has a picture of one of these pumps installed on the tank so I can see the location and orientation of the fittings for comparison.   Summit (and probably others) sell a recess plate adapter that can be installed on the tank to work around obstructions as shown below - hopefully I won't have to go that route.   If you have a picture of the installed pump I would appreciate a reply post with it.   Thanks.
Offline 1 Wild R/T
Re: Picture of installed Tanks Inc fuel pump?
« Reply #1 on: January 19, 2017 - 09:37:36 PM »
So you didn't just buy a Tanks Inc tank?.... Doing it the hard way..
Offline Katfish
  • 70 Challenger
« Reply #2 on: January 19, 2017 - 10:02:34 PM »
My spectra just arrived today, looks beautiful, seems like a bargain for $250 shipped.
We'll see if I feel the same once it's installed.....
Offline dakota
« Reply #3 on: January 19, 2017 - 10:05:26 PM »
Sadly, yes.  Started with a plan to use a mechanical fuel pump feeding a carb, but I was seduced by the rebate offered when when the FiTech injection units came out.
Offline GreenFish
« Reply #4 on: January 24, 2017 - 12:33:32 PM »
can you return the new tank and buy a Tanks Inc? Seriously the tanks inc Fuel Pump install is easy as pie on their tank. I cannot speak for anything else.
Offline dakota
« Reply #5 on: January 24, 2017 - 07:53:28 PM »
Unfortunately, I painted the tank this summer before deciding to go EFI, so returning the tank isn't an available option.   I'll have to look at the options of selling it and buying a Tanks tank or modifying the one I have.
Offline crash340
« Reply #6 on: January 25, 2017 - 07:39:22 AM »
I have just picked up my FuelPuck from Jakfab to use instead of the tanks Inc top hat POS, it'll make for a far easier and better intallation
Greg
73 Cuda
Brisbane, Australia
Offline GoodysGotaCuda
« Reply #7 on: January 25, 2017 - 09:31:28 AM »
Can you post pictures of that? I have considered it, the tanks fuel pump looks pretty crude.
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline ragtopdodge
« Reply #8 on: January 25, 2017 - 12:13:22 PM »
http://www.tanksinc.com/index.cfm/page/ptype=product/product_id=227/mode=prod/prd227.htm
Nothing wrong with Walbro pumps.  Lots of people use them.  I have one in my supercharged G35 coupe.  Works good, cheap and easily found to replace if needed.
'70 318-auto Chally 'vert
06 300c SRT8
04 2500 QCLB 4x4 HO
Offline ragtopdodge
« Reply #9 on: January 25, 2017 - 12:19:46 PM »
http://www.pro-touring.com/threads/122220-jakefab-quot-Fuel-Puck-quot-install-kit-for-TANKSINC-tanks
06 300c SRT8
04 2500 QCLB 4x4 HO
Offline dfrazz
  • 1970 Cuda - 1968 Charger
« Reply #10 on: January 25, 2017 - 02:09:34 PM »
Here is my Tanks.inc tank with their pump installed.
Offline ragtopdodge
« Reply #11 on: January 25, 2017 - 03:32:11 PM »
Is that smaller device the sending unit?
06 300c SRT8
04 2500 QCLB 4x4 HO
« Reply #12 on: January 25, 2017 - 05:27:35 PM »
Yes.
I plan on using a marine style versus a float arm. Fwiw
1976 Dodge Warlock
Offline diyhemi.com
  • Formerly Yellowfin
    • DIYHEMI.COM
« Reply #13 on: January 26, 2017 - 06:27:04 AM »
The tanks inc is good stuff. I've used these walbro pumps in Hotrods for nearly 20 years with little issue. The only thing to remember is that they don't like heat. Try not to run the tank below 1/4 or so as the fuel is the cooling liquid. Do that and it will be a solid setup.
If you continue to run the tank to empty while daily driving the car the life of the pump will drop to a year or so.
Another great replacement is the Denso oem fuel pump from a Toyota Supra, which doesn't have the same heat issue as the walbro, yet more expensive.
http://realstreetperformance.com/Fuel-Pump-Comparison-Test.html
1970 Barracuda Gran Coupe, gen III project (Cone Killing Cuda)
Offline dakota
« Reply #14 on: January 27, 2017 - 05:54:37 AM »
I ordered the recess plate from Summit ($50) and will take a shot at putting in on my tank.  Based on the pics, buying the tank already set up from Tanks Inc would've been the way to go had I decided on the EFI route sooner (cue "If I only had a brain" from Wizard of Oz).   Assuming I don't totally embarrass myself on the install, I'll post some pics on my build thread when I get to it.
