Author Topic: Replacing signal switch  (Read 1345 times)
Offline blown motor
« on: January 20, 2017 - 08:47:15 AM »
Can I replace the signal switch without removing and dismantling the steering column?
Re: Replacing signal switch
« Reply #1 on: January 20, 2017 - 09:25:11 AM »
Yes.  You'll need a puller to remove the steering wheel and crush can.  Once the crush can is removed, the switch will be right there.
There is a plastic cover on the outer column body that covers the ignition switch/turn signal switch wiring.  There are a couple screws that hold that in place.  Other then that, it's just a matter of removing the turn signal lever and the screws that hold the switch on.
Offline JayBee
« Reply #2 on: January 20, 2017 - 09:34:20 AM »
If you haven't got the tool, you can make your own crush can puller like I did.
John
1970 Barracuda convertible
2014 Toyota Avalon
Offline Katfish
  • 70 Challenger
« Reply #3 on: January 20, 2017 - 10:25:30 AM »
I used the generic puller from HF with longer screws.
Offline Racer57
« Reply #4 on: January 20, 2017 - 10:25:25 PM »
What is normally wrong when the turn lever has some slop to it ?
« Reply #5 on: January 20, 2017 - 11:17:32 PM »
The screw that holds the handle on could just be loose.
« Reply #6 on: January 21, 2017 - 07:19:23 AM »
And there is a hole in the crush can to slip a screwdriver through to tighten it.
Offline Fern
« Reply #7 on: January 21, 2017 - 11:51:14 AM »
I replaced mine, and the repop plastic switches have a lot of play in them. So even if the screws are tight it still moves up and down some.
Hopefully someone here knows of a good company to buy s switch from.
