Author Topic: 2 speed wiper help needed  (Read 899 times)
Offline Mickm
« on: January 20, 2017 - 06:25:05 PM »
Hello all,
I am rewiring the "Redfish" and ran into a problem with the wipers. They worked perfectly before I started my revamp project but soon found that I had removed one of the prongs from the swith back without knowing it. I have purchased a new NOS switch  and wired it in.
Currently, I do not have any movement in the first speed but in the second the motor will turn until it gets to a point where it stops, but you can tell it is trying to keep going but can't.
I removed the wiper arms, and the grill and moved the motor arm around but when it gets to the hard spot it is very hard to get it past.
Can someone shed some light as how I need to progress? I am going to contact AmericanAutowire to double check the wiring this week (the mopar guru was out this past week) to see why I don't have a first speed, but I need to know if this is something I can correct or do I need to replace the motor.
Any and all advice will be appreciated.
Cheers!
Mickm
MickM
