Author Topic: 383 mopar cast exhaust Flap????  (Read 1869 times)
Offline wantone
  • (O O {]{]{]||[}[}[} O O)
« on: January 21, 2017 - 11:36:18 PM »
Hi Gents!
  My 383 is a 71 and I think the motor is probably from an older model car w/o any emissions controls.  That said, I think the exhaust manifold on the passenger side was from a later car as there is a Flap that swings around.   What the heck is this and should it be open or closed considering that I don't have any exhaust provision?
Want one?  Got one! ... finally
Offline 1 Wild R/T
Re: 383 mopar cast exhaust Flap????
« Reply #1 on: January 21, 2017 - 11:45:23 PM »
Thats a heat control valve (heat riser) for warming the intake manifold to improve fuel distribution on cold days (common in Lake Forest)..... Been around since at least the fifties...
Offline wantone
« Reply #2 on: January 22, 2017 - 12:13:07 AM »
Do I leave that beauty open or closed?    Yank it off?
Offline 73440
« Reply #3 on: January 22, 2017 - 07:11:43 AM »
Is the bimetallic spring still attached?
Better to be stuck open or removed than stuck closed.
I have seen the manifolds for sale that have the valve removed and the shaft holes filled.
http://www.imperialclub.com/Repair/Exhaust/riser.htm
http://www.earlytimeschapter.org/manifoldheatcontrolvalve.html
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline jason340
« Reply #4 on: January 22, 2017 - 12:29:27 PM »
If it is working properly it should be closed when the engine is cold and when the engine heats up the flapper should be open, Hope this helps.
Offline wantone
« Reply #5 on: January 22, 2017 - 10:05:00 PM »
Thanks gents!    Given that i'm in Cali- i'm going to wait to see if it's open when warm... If not, i'm tossing that into the ocean.
« Reply #6 on: January 28, 2017 - 08:11:05 AM »
I leave the cross shaft in so it will look stock but remove the plate  no need for it unless you are driving it in winter conditions
