Author Topic: Convert from drum to disk brakes  (Read 1605 times)
Offline battrm
« on: January 22, 2017 - 05:55:35 PM »
I am wanting to change my car from factor drum brakes to factor disk brakes.
I have a 1971 cuda with 11" drum on the front and I was wondering what it would
Take to convert to manual disk on the front.  Any input would be appreciated.  Thanks
Offline Cudakiller70
Re: Convert from drum to disk brakes
« Reply #1 on: January 23, 2017 - 12:21:46 AM »
Have you seen these kits? There's a stage 3 & 4 kits also. My car was already done so I don't have experience with these.
http://www.doctordiff.com/10.95-front-disc-brake-kit.html
http://www.doctordiff.com/front-disc-brake-kit-for-11.75-on-disc-knuckles.html
« Last Edit: January 23, 2017 - 12:25:56 AM by Cudakiller70 »
The above is just my opinion
John Adams
Offline dakota
« Reply #2 on: January 23, 2017 - 06:25:32 AM »
I bought one of the front disc conversion kits from Right Stuff primarily because of the relatively low cost.  I don't have any road experience with it yet, but so far the installation has been pretty straightforward.   From what I can tell, most of these conversion kits require at least a 15" minimum wheel diameter.   Depending on whether your car has power brakes or not, you may need a power brake booster too.
One option I came across recently:
http://ssbrakes.com/i-10092523-mopar-b-and-e-body-front-4-piston-power-disc-brake-conversion-kit-a156-1.html
This is described as fitting "most" 14 inch wheels using the drum spindles, but you'd need to check with them.   I don't remember seeing this kit when I was looking a couple of years ago, because if it fits 14's I could have avoided the wheel and tire upgrade I have ahead of me now.
There are LOTS of other options available if you want to spend the $$$.
Offline bc3j
« Reply #3 on: January 23, 2017 - 01:58:35 PM »
The kit I bought from CPP via Classic Industries had the small standard rotors with slider calipers and fit inside my 14" Road Wheels (magnum 500). I since put the 11.75" Cordorba rotors on, still with the same slider calipers but larger adapters, and had to go with 15" rims.  This kit used A Body spindles.
Offline battrm
« Reply #4 on: January 23, 2017 - 05:30:32 PM »
Would the stage 1 ( 10.75 manual disk ) from dr diff be much
Of an up grade over front drum brakes.  I could go to stage 2
Set up but I would need to up grade to 15" wheels.  Any thoughts.
Offline bc3j
« Reply #5 on: January 23, 2017 - 11:51:31 PM »
Well it depends on what your doing with the car...spirited street, auto x, racing etc.
I think discs are better than drums. I originally used the standard rotors you mentioned and the car stopped good.  I upgraded to 11.75" rotors simply because I wanted to and they provided a slightly larger radius for a little better stopping.
There's a lot of high $$$ kits out there, but for a cruiser I think the standard rotors work pretty good.  Remember a lot of the manual brake pedal feel is a personal thing so you can match master cylinder bore to what you like.
A lot of mopar guys at the local cruise-ins by me still use drums and like them.  Overall, I prefer discs over drums.
Hopefully, some of the other guys can give you some good suggestions and other alternatives that they tried and found to be successful.
« Last Edit: January 24, 2017 - 12:51:59 AM by bc3j »
Offline CudamanTom
« Reply #6 on: January 27, 2017 - 09:04:10 AM »
I replaced my front drums.
here are a few pics and shows the tools I used.
Very easy to do with proper tools.  :bigsmile:
here is the link, and about half way down the thread page.
http://www.cuda-challenger.com/cc/index.php?topic=97175.90
1971 Cuda 440-727 - (clone)
Because I like it fast!!!
Offline HP_Cuda
  • Mopar or No Car!
« Reply #7 on: January 27, 2017 - 12:41:15 PM »
Offline battrm
« Reply #8 on: January 29, 2017 - 07:33:38 AM »
Thanks for the help guys.
