Oil pressure & water temps?
Author Topic: Oil pressure & water temps?  (Read 1027 times)
Offline thunderbyte
  • I'm a llama!
« on: June 28, 2005 - 05:59:02 AM »
My water temps ar usually between 170 and 190 deg f.  I have seen them get as high as 200, but only when its very hot out (around 90 F)  Are these safe operating temps?
Also, I have watched my oil pressure, and this is what I have found:
0mph, 600rpm, 18psi
20mph, 1100rpm, 40psi
35mph, 1500rpm, 45psi
55mph, 2200rpm, 60psi
Sound ok?
This is in a 73 340 Cuda, stock except for headers and a mild cam, bored .030 over.
Thanks for any input.
Offline OUTLAW
  • MASTER OF ALL THINGS MOPAR
  • I didn't say you can't RACE--I said you can't WIN
    • MOPAR-MADNESS  WEB/FORUM
Re: Oil pressure & water temps?
« Reply #1 on: June 28, 2005 - 06:39:05 AM »
Yep they are all fine for stock
what weight oil you running ? Personally I like a little more at idle but 18 at 600 rpm is ok , your not hurting the motor any
Offline 71fish
  • Bless you..
    • Ken's 71fish
« Reply #2 on: June 28, 2005 - 07:51:36 AM »
I have a warmed up 340.. was driving her around this weekeend when it was 95° here in joisey and on highway it was 170° and did not get hotter than 190°.. 195° when idling for 15 min in Ritas parking lot  lol
Oil pressure is higher @ iddle.. prob around 28-30, but I run 20W-50 during the Summer.
71fish
71fish - Nobody better than an E-BODY!!
Offline thunderbyte
  • I'm a llama!
« Reply #3 on: June 28, 2005 - 09:49:29 AM »
Im running 10w-40.  The 600rpm at idle is in gear.  I should check again in park.  Thanks for the input. :)
My car is also ac equipped from the factory.  It doesnt work, so I am considering pulling it.  That would get the ac radiator from in front of my cooling radiator, as well as get rid of some weight and rotating mass.  I would just tag it and bag it in case I decide to sell someday, it could go back on.
dodgetkboy78
« Reply #4 on: June 30, 2005 - 12:38:56 AM »
perfect! :thumbs: :thumbs: :thumbs: :thumbs:
under 220 is ok, just dont work it hard over 210 (my rule of thumb)
Just for another reference,
My racetruck 318 has about 10 pounds at idle (900)
2000 (25 pounds)
3000 (40 pounds)
4000 (60 pounds)
5000 (75 pounds)
It has stock pump, high pressure spring, and mopar's own oil mods done to it. :thumbs:
dodgetkboy78
« Reply #5 on: June 30, 2005 - 12:40:14 AM »
oh, yeah! DITTO on the 20w50 (or 40W synthetic)
