Author Topic: oh dear... dead in the water  (Read 5123 times)
Offline Strawdawg
    • Vortex Buicks
Re: oh dear... dead in the water
« Reply #30 on: January 26, 2017 - 03:13:29 PM »
Is the 3310 showing correct float levels or was it pumping gas into the carb from a float problem?
Offline wantone
  • (O O {]{]{]||[}[}[} O O)
« Reply #31 on: January 26, 2017 - 04:42:07 PM »
I know I had the floats set correctly given I used the method of rocking the car with the sight plugs open and barely anything sloshing out.   Would there be another reason?
Want one?  Got one! ... finally
Offline Strawdawg
    • Vortex Buicks
« Reply #32 on: January 26, 2017 - 05:50:56 PM »
a 3310 is calibrated a bit on the rich side from the factory as it was intended to be a performance carb used with a bit more cam that a stock engine...on the other hand, it really tends on how rich it actually is and what signs you have to come to that conclusion.  A smeel exhaust is not always a good sign...
But, I would guess the next most common factor would be a blown power valve, or a power valve with too high a vacuum rating so that (in either case) the PV is passing fuel when it should be closed.
Offline wantone
« Reply #33 on: January 27, 2017 - 11:18:06 AM »
I had a new PV 6.5#.   The Vac at idle in park is 15 so it's all good to use the 6.5.   Since that big backfire, I can't get the car moving.   The new BR shows up today so I'll hopefully have good new by this afternoon.
Offline HP_Cuda
  • Mopar or No Car!
« Reply #34 on: January 27, 2017 - 12:32:00 PM »
Did you get a reading with someone else when the car was running in the on position?
If it varied more than say 4+ " then your PV is most likely gone. It won't hurt to change it, just the time to do it.
Offline jhaag
« Reply #35 on: January 27, 2017 - 01:04:51 PM »
depending on how old the carb is, it may have blowout protection. simple check ball installed in the vacuum passage.  :dunno:
love 70 Challengers
Offline Strawdawg
    • Vortex Buicks
« Reply #36 on: January 27, 2017 - 03:31:30 PM »
As he said, the 3310 may not have backfire protection and the power valve is probably history..that's what often happens after a backfire.
Offline wantone
« Reply #37 on: January 27, 2017 - 07:41:35 PM »
Hey guys!  GREAT news... The NEW Ballast Resistor is the answer.   Upon pulling the old one, I saw that the screw between the two prongs was busted.   So when I got no reading in resistance, there was a good reason for that... HOO RAYYYY  :ylsuper:
A BIG THANK YOU to all of you for your time and effort.   Being 33  I had no idea what a ballast resistor does and how it can affect the car.    I still don't get it all the way but it sure can interrupt your spark while the car is in the ON position haha.    sincerely
THANK YOU ALL!!!!    :cooldancing: :worshippy :worshippy :worshippy
« Reply #38 on: January 27, 2017 - 07:54:19 PM »
 :clapping:  I hope you bought a spare for the glove box!  :grinyes:
Offline 73440
« Reply #39 on: January 27, 2017 - 08:19:18 PM »
Like understanding how color tv works , you dont need to know just enjoy it.
You just have to understand what it wants to work.
Understanding how can come later.
67 440
72 413 / 727
73 Barracuda w/ 68 440
01 Chevy van 420, 520 miles
73 HD Ironhead
82 HD Ironhead
74 Norton 850
80 HD Shovelhead
80 Husqvarna WR 390
Offline 734406pk
  • Andy
« Reply #40 on: January 27, 2017 - 09:42:08 PM »
Glad you found it! Enjoy!! :bananasmi
